Defining the properties of a CPE Reference
To define CPE Reference properties, select the CPE Reference note and edit the values in the Properties window.
The following table describes the properties of a CPE Reference mapping definition.
Property |
Description |
CPE Reference |
Name of the subevent associated with the date and time values provided in the Date and Time nodes. Subevents are defined by their date and time attributes. In visits that are unscheduled and repeating, each instance of the visit corresponds to a subevent within a CPE in Oracle Clinical. REQUIRED.. |
CPE Name |
Name of the CPE for the CPE Reference. |
ItemSets output as |
Method to use for handling itemsets in exports.
Repeating Pages output as |
Method to use for handling instances of repeating forms in exports. RepeatSequence is the default:
