Defining a control mapping
A control mapping definition consists of:
- The RefName path of the control.
- The CPE Reference identifying the subevent with which the control is associated.
- Additional properties used to characterize and group the data in Oracle Clinical.
If you are creating mappings for a whole trial, the simplest way is to let the InForm Architect application display RefName paths for all controls at once. Then you can then edit their properties individually to complete their definitions.
You can also create definitions of individual control mappings, specifying their RefNames and their properties.
