Overview
This chapter gives you a quick tour of the InForm Architect application. It introduces you to the main application window, the workspace, and toolbars that you will use in setting up and managing trial components. Additionally, it describes how to start and stop the InForm Architect application.
If you are unfamiliar with how to work with applications that have multiple windows and toolbars, be sure to read the following sections:
