Screening and enrollment forms
Each trial is required to have a Screening form and Enrollment form. To enable the special system processing that occurs when a user submits data for these forms, the forms have several implementation requirements. When you create forms, you define item, section, form, and visit components. Screening and Enrollment forms have the following requirements for these components:
- The Screening form must be the only form in its visit, which is defined by a screening visit.
- The Enrollment form must be the only form in its visit, which is defined by an enrollment visit.
- When you define Screening and Enrollment visits, forms, sections, and items, you must include specific UUID attributes. For more information, see Screening UUIDs and Enrollment UUIDs.
- The Screening form must include the Patient Initials item, which requires specific UUIDs. For more information, see Patient Initials data entry item.
- The Enrollment form can include an editable Patient Number item, which requires specific UUIDs. For more information, see Patient Number data entry item.
- At least one item is required on each form.
