Subjects: Subject Status Dates
The Subjects: Subject Status Dates report elements return dates when subjects were assigned to particular states in the InForm application.
Subjects may be set to some states more than one time. For these states, First and Last date report elements appear in the Query Studio tree. Use these report elements to identify when subjects are moved from one state to another, as follows:
- Use Last dates to determine the current status for a subject and the date on which the status change occurred.
- Use the First and Last dates together to identify subjects who were, but are no longer, in a given state.
Report element
Description
Subject Status Date
Data type: Date/Time
Description: The date on which the subject was assigned the current subject status. For example, if the current subject state is Complete, the Subject Status date indicates the date on which the subject status was set to Complete.
Date type: System date (GMT).
InForm Screened Date
Description: The date on which the subject was screened for the study in the InForm application. A Screened status indicates that the Screening form for the subject was started, but the subject is not yet enrolled. This covers these cases:
- The subject is fully screened, but the enrollment form has not been started.
- The subject is fully screened and the enrollment process has started but not completed.
Data type: Clinical
InForm Enrolled Date
Description: The date on which the subject was enrolled in the InForm application. A status of enrolled indicates the subject was properly enrolled in the InForm application, but has not reached the status of randomized, completed, or dropped out.
InForm Screen Failure Date
Description: The date on which the subject failed the screening process.
InForm Randomized Date
Description: The date on which the subject was randomized through the InForm application. A status of randomized indicates that a subject was enrolled and randomized in the InForm application, but is not yet completed or dropped out.
Note: If you perform randomization outside of the InForm application, the resulting report column does not contain randomization data.
First Dropped Date
Description: The date on which the subject first dropped out of the study, as recorded in the Study Completion form for that subject.
Last Dropped Date
Description: The date on which the subject most recently dropped out of the study, as recorded in the Study Completion form for that subject. If the subject is removed from the dropped out state, the resulting report column does not contain data.
Subject First Complete Date
Description: The first date on which the subject completed the study, as recorded in the Study Completion form as designed per InForm requirements.
Subject Last Complete Date
Description: The most recent date on which the subject completed the study, as recorded in the Study Completion form as designed per InForm requirements. If the subject is removed from the Complete state, the resulting report column is does not contain data.
CRB SV Ready Date
Description: The date on which the case book was marked SV ready.
CRB Frozen Date
Description: The date on which the case book was frozen in the InForm application. If the CRB is unfrozen, the resulting report column does not contain data.
CRB Signed Date
Description: The date on which the case book was signed in the InForm application. If the CRB is not signed, the resulting report column does not contain data.
CRB Locked Date
Description: The date on which the case book was locked in the InForm application. If the CRB is not locked, the resulting report column does not contain data.
