Forms: Properties
Forms: Properties report elements return information about the properties associated with forms.
Report element |
Description |
Form Type |
Data type: String Description: Displays the type of form. Valid values are:
Use the predefined form filters with this element to limit the data on your report to a particular form type. Data source: Derived for the report; not stored in the Reporting and Analysis database. Value decoded for display. |
Is Dynamic |
Data type: Y/N Description: Specifies whether the form is dynamic. Valid values are:
Data source: Replicated from the InForm transactional database to the Reporting and Analysis database and decoded for display. |
Is Repeating |
Data type: Y/N Description: Specifies whether the form is a repeating form. Valid values are:
A repeating form occurs multiple times in the same visit or study. For example, if a protocol calls for multiple blood draws at intervals after administering a medication, you can capture the repeating data on multiple instances of a repeating form. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database and decoded for display. |
Is Common |
Data type: Y/N Description: Specifies whether the form is a common form. Valid values are:
Is Alternate Form |
Data type: Y/N Description: Specifies whether the form is an alternate form. Valid values are:
Contains SV Required Items |
Data type: Y/N Description: Specifies whether the form contains items that require Source Verification.
Contains Required Items |
Data type: Y/N Description: Specifies whether the form contains items that require data entry for the form to be complete. Valid values are:
Form Order |
Data type: Numeric Description: An ordinal that specifies the position of the form within the visit. For example, 3 indicates that the form is the third form in the visit. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database and decoded for display. |
Design Note |
Data type: String Description: Optional text, as specified in the study design code, that is used by study designers for documentation purposes only. This note does not appear in the InForm interface. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Form Note |
Data type: String Description: Optional text, as specified in the study design code, that appears on the form. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Is SV Selected |
Data type: Y/N Description: Indicates whether the form has been selected for source verification.
