I can't see subject status information
The subject status that appears in reports depends on which InForm features you use to set the state. For instance, to display status data for a subject in the Randomized state, you must perform subject randomization through InForm.
To see subject status information in a report, make sure that your study meets the following criteria.
Subject status requirements
Subject status |
Required action in the InForm application |
Screened |
InForm Screening form (as designed per InForm requirements) must be successfully submitted for the subject. |
Enrolled |
InForm Enrollment form (as designed per InForm requirements) must be successfully submitted for the subject. |
Screened Failed |
InForm Screening form (as designed per InForm requirements) must be submitted for the subject. The subject subsequently fails the InForm screening process. |
Enrolled Failed |
InForm Enrollment form (as designed per InForm requirements) must be submitted for the subject. The subject subsequently fails the InForm enrollment process. |
Enrolled Override |
InForm Enrollment Override process must be successfully completed after the subject initially fails screening or enrollment. |
Randomized |
Subject must be randomized in InForm. |
Dropped Out |
InForm Study Completion form (as designed per InForm requirements) must be completed for the subject. The form must indicate that the subject has dropped out of the study. |
Completed |
InForm Study Completion form (as designed per InForm requirements) must be completed for the subject. The form must indicate that the subject has completed the study. |
