Revision history
Revision history
Date |
Revised part number |
Description |
September 2021 |
F30306-04 |
In the InForm standard reports section:
March 2021 |
F30306-03 |
In the Prerequisites section:
November 2020 |
F30306-02 |
In the What if section, updated the following topics to explain that for SSO and non-SSO studies, when you log out or are timed out of InForm, your Cognos session, which is in a separate tab in the same browser window, is invalidated as result. There is no notification provided for this. Any unsaved changes in Cognos are lost. When you attempt to perform an action in Cognos, the Cognos log in page appears and you need to enter your InForm study credentials (user name and password) and the InForm study name. |
In the CRF Signature Status Report topic, updated the Type column description to make clear that the report provides both CRF level and Book level signatures. |
Added this Revision History topic. |
August 2020 |
F30306-01 |
Original version of this document. |
