Can I skip an item or form?
Yes. However, for a form to be complete, you must enter all required items (marked with an asterisk).
- If you don't have all of the data when you fill in a form, skip the missing items. When you submit the form, the missing items have a yellow background, and you can enter the data later.
- If your study protocol allows it, you might need to skip an item or a form permanently if:
- The item or form does not apply to the subject.
- The data is not available.
- The procedure to collect the data was not done, and the data was not collected.
To mark an item or form as skipped, create a comment on the item or form. For more information, see Mark a form or item as incomplete.
