6 Defining Variables and Parameters
See Defining Table Columns for information on defining Columns.
- About Variables, Parameters, and Columns
- Defining Variables
Oracle LSH creates Variables automatically based on the Oracle columns or SAS variables that you load or upload from an external system. In addition, you can create Oracle LSH Variables manually, either directly or as part of the process of creating a Table Column or a Parameter. - Using the Variable Properties Screen
This section contains the following topics. - Defining Columns
- Defining Parameters
- Using the Parameter Properties Screen
- Setting Up Parameter Value Propagation
You can set up Parameter value propagation only in the context of a Workflow or Report Set. - Defining and Using Parameter Sets
- Defining Programatically Generated Lists of Values and Value Validation
- Modifying Parameters
In the Oracle Life Sciences Data Hub (Oracle LSH) a Variable is the definition source for both Table Columns and Parameters. Its attributes include data type, length, name, default value, and Nullable (Yes/No). These attributes form the basis of both Columns and Parameters; both Columns and Parameters are instances of Variables. Both have additional attributes. Parameters also serve as definitions for Parameter instances, making the only three-level definitional relationship among Oracle LSH objects.
You can use the same Variable as the definition source for multiple Columns and Parameters. This promotes consistency and compatibility: for example, if you base the Study Column of all Tables in a single data flow on the Study Variable, and the Study Parameter of all the Programs that read from and write to those Tables on the same Variable, the Columns and Parameters have the same data type and length, and Nullable setting.
The Nullable attribute, whose default value is Yes in a Variable, is expressed in opposite ways in the user interface for Columns and for Parameters. When you see a Variable whose Nullable attribute is set to Yes through a Column, you see a Nullable setting whose default value is Yes, like the Variable's. When you see the same Variable through a Parameter definition, you see a Required setting whose default value is No. This is the same attribute setting expressed in different ways: if a Variable is Nullable, it is not Required; if it is Required, it is not Nullable.
Parent topic: Defining Variables and Parameters
Defining Variables
This section includes the following topics:
Creating Variables Automatically
Oracle LSH creates Variables automatically based on equivalent metadata in external systems in two basic ways:
- Creating Variables through Load Sets
- Creating Variables by Uploading SAS Data Sets and Variables during Table Definition
Oracle LSH creates Variables automatically when you define or run Load Sets to load data from an external system. These Variables have the same data type and length and other attributes as the external metadata on which they are based.
You can use these Variable definitions within the Application Area where they are created. You can also copy or move them into a Domain library for the purpose of reuse in other Application Areas, according to your organization's policies.
Oracle LSH creates Variables from Load Sets as follows:
SAS. When you define a SAS-type Load Set, you can choose to create the Load Set's Table Descriptors from the SAS Data Sets you want to load. Oracle LSH creates a Table definition for each SAS data set and an Oracle LSH Variable for each SAS variable. The Oracle LSH Variables and Table definitions are located in the same Application Area as the Load Set definition.
Oracle Tables and Views. When you define a Load Set of type Oracle Tables and Views, you can choose to create the Load Set's Table Descriptors from the Oracle tables or views you want to load. Oracle LSH creates a Table definition for each external Oracle table or view and a Variable for each external column. The Variables and Table definitions are located in the same Application Area as the Load Set definition.
Oracle Clinical Data Extract. When you define an Oracle Clinical Data Extract (DX) View Load Set (either Oracle or SAS), you can choose to upload the Load Set's Table Descriptors from the DX Views you want to load. Oracle LSH creates a Table definition for each DX View and a Variable for each Column. These Variables and Table definitions are located in the same Application Area as the Load Set definition.
Oracle Clinical Global Library. When you run a Global Library Load Set, Oracle LSH creates a Domain with the same name as the Oracle Clinical Domain whose Global Library you are loading (if it does not already exist) and converts all Oracle Clinical Questions to Oracle LSH Variables. If a Question is assigned a Discrete Value Group (DVG) in Oracle Clinical, Oracle LSH also creates a Parameter based on the Variable and gives it a list of values corresponding to the DVG values. Oracle LSH also creates a Table definition from each Question Group.
Parent topic: Creating Variables Automatically
When you create a new Table in Oracle LSH, you have the option to upload the metadata of a SAS data set, including its variables. When you add a Column to an Oracle LSH Table, you have the option to upload a SAS variable. In both cases, the system converts each SAS variable to an Oracle LSH Variable.
You have the same options when you create a Table Descriptor, which is a Table instance contained in a Program or other executable object.
Creating Variables Manually
Every time you create a Column (in a Table Definition) or Parameter (in a Program, Report Set, or Workflow definition or directly in a Parameter Set definition ) you have the option to manually create a Variable or to select an existing Variable as the definition source of the Column or Parameter.
To promote consistency and compatibility, use existing Variables as often as possible. See Defining and Using Parameter Sets for more information.
When you click Create LSH Variable in either the Create Parameter or Create Column screen, additional fields appear.
Modifying Variables
To modify a Variable, do the following:
If you wish, you can update one or more Parameters that reference this Variable to reference the new version by using the Upgrade All Instances function in the Actions drop-down list. See Upgrading One or More Instances from the Definition.
Definition Properties
You can click Update to modify any of these properties.
Name: See Naming Objects.
Description: See Creating and Using Object Descriptions for further information.
Data Type: Variables can have a data type of VARCHAR2, NUMBER, or DATE. See Creating Variables Manually for more information.
Length: You can change the length of a VARCHAR2 or NUMBER Variable. See Creating Variables Manually for more information.
Precision: See Creating Variables Manually for more information.
Oracle Name: See Creating Variables Manually for more information.
SAS Name: See Creating Variables Manually for more information.
SAS Label: See Creating Variables Manually for more information.
SAS Format: This is the SAS representation of the data type for this Variable. See Creating Variables Manually for more information.
Default Value: This field shows the default value, if any, for the Parameter definition that refers to this Variable.
Nullable: This field shows whether the Parameters of this Variable can contain null values or not. See Creating Variables Manually for more information.
Validation Status: This field displays the current validation status of the Variable. If you have the necessary privileges, you can change the validation status by selecting Validation Supporting Information from the Actions drop-down list. See Validating Objects and Outputs for further information.
Status: This field displays the installable status of the Variable. A Variable is always Installable. See Installation Requirements for Each Object Type.
Checked Out Status: This field displays the status of the Variable: either Checked Out or Checked In. See Understanding Object Versions and Checkin/Checkout for further information.
Checked Out By: This field displays the username of the person who has the Variable checked out.
Latest Version: If set to Yes, this is the latest version of the Variable definition.
Version: This field displays the current version number of the Variable.
Version Label: This field displays the version label, if any, for the Variable version.
Parent topic: Using the Variable Properties Screen
Buttons
Check Out: Click the Check Out button to check out the Variable. The button is grayed out if the Variable is already checked out.
Update: Click the Update button to modify a Variable. The button is grayed out if the Parameter is not checked out or checked out by someone else.
Defining Columns
Defining Columns is covered in Defining Table Columns in the chapter on Tables.
Defining Parameters
See also:
About Parameters
In Oracle LSH you must create a defined object called a Parameter for each input and output parameter in a Program's source code.
In Workflows and Report Sets you can define Parameters especially for the purpose of passing their value (to be set in the Execution Setup definition or at runtime) to other Parameters you specify within the Workflow or Report Set, reducing the number of Parameters to be set at runtime. You can also pass the value of an output Parameter of one Program in a Workflow or Report Set to the input value of another Parameter in the same Workflow or Report Set (see "Setting Up Parameter Value Propagation").
A Load Set, Data Mart, and Business Area contains Parameters defined by adapters used to create these objects. See Setting Load Set Parameters, Setting Data Mart Parameter Values, and Setting Business Area Attributes and Parameters for more details.
A Parameter definition inherits attribute values from its source Variable (notably data type, length, and default value, if any) and has additional attributes such as Required, Visible, and Read Only, and its list of acceptable values, if any.
Using Parameters
You can use Parameters to increase the reusability of a Program; for example, if you hardcode a value in source code and then want to change the value, you must create a new version of the Program definition and revalidate it. No revalidation of the Program definition is required when you rerun the same Program using a different Parameter value.
Your company may develop a library of standard Parameters that are compatible with standard Table Columns and available for reuse throughout Oracle LSH. Using standard Parameters and Table Columns facilitates reusing Programs on different data and streamlines Parameter value propagation in Workflows and Report Sets.
For example, you can create a Parameter Set containing Parameters based on the same Oracle LSH Variables as the Columns in each standard Table, so that when you search for a Parameter definition in a Program that will read from or write to a standard Table, you can search in the Parameter Set with the same name as the Table.
Some more examples of Parameter usage:
Run on different data. Define a standard study demography report Program definition and promote it to a Domain library. Create instances of this Program in multiple Application Areas, each of which contains data for a different study. Bind the value of the Study Parameter in the Execution Setup for each Program instance to the appropriate Study Parameter value.
Or create a required Parameter settable at runtime to determine whether a Program uses local lab range definitions, standard published reference ranges, or panic ranges.
Similarly, use a Parameter to determine whether you run a Program on all adverse events or only serious adverse events; or use a Parameter to determine whether you run a Program on all Oracle Clinical Data Clarification Forms (DCFs) or only those that have been outstanding for a certain time period.
Generate different report formats. Use a Parameter to generate multiple reports on the same data, each in a different format. For example, create a Parameter called Format with the values Table, Listing, and Figure. Write the source code so that if the input value of the Format Parameter is table, the program produces a table, and so on. If you want to include each format in a Report Set, but want each report to be in a separate Report Set Entry, you can define an instance of the same Program definition in each of three Report Set Entries and bind the Format Parameter to a different value in the Execution Setup of each Program instance.
Run on a subset of data. Use Parameters for subsetting data; that is, limiting the rows processed in a single Table. For example, from a single table that includes data on both male and female patients, you might choose to report data separately, processing only patients whose Sex Parameter value is Male or only patients whose Sex Parameter value is Female. To run the same Program both ways automatically, create two instances of it in a Workflow or Report Set and bind the value in the Execution Setup of each instance so that each instance uses a different value for the Sex Parameter.
Parent topic: About Parameters
Parameters and Execution Setups
When you generate a default Execution Setup for a Program, the system automatically includes a copy of all the Parameters you have defined.
You can modify Parameter settings in the Execution Setup to control the options available to the person submitting the Program for execution; for example, if a Parameter is set to Read-Only in the Execution Setup, a user submitting the Program for execution cannot change the value of that Parameter. Execution Setups contain a copy of the Parameters and changes made to Parameters in Execution Setups do not affect Parameter settings in a Program definition or a Parameter definition.
You can define multiple Execution Setups, each with different Parameter settings; see Creating, Modifying, and Submitting Execution Setups.
Creating a Parameter
Figure 6-1 Process of Creating the First Parameter Instance in a Program, Report Set, or Workflow
Description of "Figure 6-1 Process of Creating the First Parameter Instance in a Program, Report Set, or Workflow"
When you create a Parameter in a Program, Report Set, or Workflow, you are actually creating an instance of a Parameter definition. Follow the instructions below.
When you create a Parameter in an Application Area or Domain, you are creating a Parameter definition only, but you can follow the instructions at Create a New Parameter Definition and Instance.
To create a new Parameter instance:
Parent topic: Defining Parameters
To create a new Parameter definition and instance at the same time, do the following:
Parent topic: Creating a Parameter
Create Parameters from an Existing Parameter Set
You can create multiple Parameters at the same time by creating instances of all the Parameters in a Parameter Set. This option appears only the first time you add a Parameter to a Program or other executables. See Defining and Using Parameter Sets.
To create a new Parameter definition from an existing Parameter Set, do the following:
If necessary, you can remove Parameters you do not need by selecting them and clicking Remove.
To continue defining the Parameter, click its hyperlink. Follow instructions for Defining Parameter Details.
See also Setting Up Parameter Value Propagation.
Setting a Method of Determining Value
If you are defining a Parameter in the context of a Workflow or Report Set, you have a choice between the following methods of determining the Parameter value. You must choose one.
If you are defining a Parameter for a Program that is not part of a Workflow or Report Set, getting the Parameter's value from another Parameter is not possible and this choice does not appear.
Define Value. The Parameter's value must be set manually; either here, or in the Execution Setup, or at runtime. You can specify one of several ways to determine allowable value(s). See Defining Allowed Values.
Get Value From Another Parameter. You can set up value propagation within a Workflow or Report Set so that this Parameter receives its value from another Parameter in the same Workflow or Report Set. See Setting Up Value Propagation from the Target Parameter.
Parent topic: Defining Parameter Details
You can specify the values allowed for the Parameter in several ways, found in the List of Values drop-down list. The system displays the appropriate interface for defining each after you make a choice.
None. No list of allowable values is associated with the Parameter. The user can enter any value. You can define a Program to validate the value; see Defining Programatically Generated Lists of Values and Value Validation.
You can specify a default value. To force the user to set a value at runtime, select Required and do not set a default value.
The system validates that the default value conforms to the Parameter's data type and length (defined in the source Variable). If the data type is Date, the system checks that it is in the format specified in User Preference.
Static List of Values. Create a list of specific values you want to allow for the Parameter. These values will appear as the only possible choices for the Parameter. Click Add Value to enter each value you want to allow. The system will display them in the list of values in the order in which they appear here.
You can select one value to be the default value if you want to. To force the user to set a value at runtime, select Required and do not set a default value.
The system validates that each value you define conforms to the Parameter's data type and length (defined in the source Variable).
Do not enter a comma (,) in the Parameter value string. The system interprets a comma as a delimiter between two different Parameter values.
Classification List of Values. This option results in a list of allowable values that comprises the values at a particular level of a classification hierarchy.
Select a classification hierarchy and level. The system generates a list of values equal to the set of values defined for that hierarchy level. For example, if you choose the Project, Study, and Site hierarchy and the Study level, the list of values includes all the Study names.
If you define two Parameters in the same Program and base their allowed values on the same classification hierarchy, on two adjacent levels, the allowable values for the Parameter associated with the lower level are limited to those with a relation to the value chosen for the Parameter associated with the higher level.
For example, if you define two Parameters whose possible values are linked to the Project, Study, and Site hierarchy, with one associated with the Project level and the other associated with the Study level, the possible values for the Project level Parameter include all the Project values in the hierarchy. However, the possible values for the Study level Parameter are limited to those related to the particular Project value selected. If the value for the Project-level Parameter is Project 1, the list of values that appears for the Study-level Parameter includes only those studies that are part of Project 1. If you change the value of the Project level Parameter to Project 2, the list of values for the Study level Parameter changes to studies that are part of Project 2.
The same is true for Parameters linked to each lower level. In this example, you can define a third Parameter associated with the Site level whose values are limited to sites that are part of the particular study selected.
Program Generated List of Values. You can define an Oracle LSH Program, or Source Code within a Program, specifically for the purpose of dynamically generating a list of values for a Parameter. You must check in and install the Program.
You must write the source code in PL/SQL and use the following syntax to generate a list of values:
FUNCTION <function name> (pi_paramRef IN CDR_PARAMETER_OBJ_TYPE, pi_paramColl IN CDR_PARAMETER_COLL) RETURNS CDR_VALS_COLL;
Click the Search icon and specify the Program and Source Code you want to use to generate the list of values for the Parameter.
See Defining Programatically Generated Lists of Values and Value Validation for further information.
Setting Validation Rules
You can choose a method of validating the Parameter's value. If you select a method, the system validates the Parameter value when the Program is submitted for execution. If the Parameter has an invalid value, the system returns an error message and does not execute the Program.
If you set a default value, the system validates its data type and length each time you modify the Parameter.
You can choose one of the following methods of validating the Parameter's value:
None. You can choose to accept any value entered by the user.
Programmatic. You can define an Oracle LSH Program specifically for the purpose of dynamically validating the Parameter value. You must check in and install the Program. See Defining Programatically Generated Lists of Values and Value Validation for further information.
Click the Search icon and specify the Program that contains the Source Code you want to use to validate the value of the Parameter.
Validate Against LOV. If you defined a static list of values for the Parameter, the system accepts the entered value only if it appears on that list.
- About the Parameter Properties Screen
- Instance Properties
- Define Values
- Validate Values
- Definition Properties
- Variable Properties
- Buttons
You can reach this screen from Oracle LSH object definitions, instances, and Execution Setups. Click Update to make changes to any of the settings but note the following:
Changing Parameter properties from an object's instance is the same as changing Parameter properties from an object's definition. This is because Parameters belong to an object definition.
The changes you make to the Parameter properties become the default settings for all new Execution Setups for this object instance. But any existing Execution Setups do not get updated with the changed Parameter properties until you upgrade those Execution Setups.
If you are in an Execution Setup, the changes you make to the Parameter apply only to the Execution Setup.
See Modifying Parameters for information on modifying Parameter properties.
Parent topic: Using the Parameter Properties Screen
Instance Properties
You can see the following instance properties:
Name: You can click Update and modify the name. See Naming Objects for further information.
Description: You can click Update and modify the description. See Creating and Using Object Descriptions for further information.
Visible: If set to Yes, the Parameter is visible by default in the Execution Setup of the instance. If set to No, the Parameter is not visible by default. You can choose to keep this setting as Yes in an object definition or instance, and change it whenever required, in an Execution Setup.
Changes made to Parameter properties from an Execution Setup do not affect Parameter properties in the object's definition because Execution Setups maintain an independent copy of the Parameters.
Required: If set to Yes, you must provide a value for this Parameter in the Submission form for this instance. This setting is applicable only to visible Parameters. You can choose to keep this setting as No in an object definition or instance, and change it when required, in an Execution Setup.
Read Only: If set to Yes, you cannot change the value of this Parameter. You can choose to set this property to No in an object definition or instance, and change it whenever required, in an Execution Setup.
Input/Output: This setting indicates the type of Parameter. Parameters can be of type Input, Output, or Input/Output.
Prompt: This is the display prompt for the Parameter. By default it is the same as the Parameter's name.
Definition: You can upgrade to a new version of the same definition. See Upgrading to a Different Definition Version from an Instance.
Version: This field displays the current version number of the Parameter instance.
For further information on object versions, see Understanding Object Versions and Checkin/Checkout.
Validation Status: This field displays the current validation status of the Parameter instance. See Validating Objects and Outputs for further information.
Status: This field displays the installable status of the Parameter: Installable or Non Installable. The installable status of a Parameter depends on the installable status of its parent object. See Installation Requirements for Each Object Type for more details.
Define Values
This section displays the following settings:
List of Values: If you have provided a method to determine the Parameter's value, a list of values that are valid for the Parameter appear here. Else the value for this field is None.
Default Value: If you have specified a default value for the Parameter, the value appears here.
See Defining Allowed Values for more details on defining values for Parameters.
Validate Values
Method of Validating Values: If you have specified a method to validate Parameter values, that method name appears here. See Setting Validation Rules for more details.
Checked Out Status: This field displays the status of the definition: either Checked Out or Checked In. All Parameter properties belong to the Parameter definition as well as the Parameter instance. You can modify all properties from the Parameter instance whether or not the Parameter definition is checked out. See Understanding Object Versions and Checkin/Checkout for further information.
Latest Version: If set to Yes, this Parameter instance is pointing to the latest version of the Parameter definition. If set to No, this Parameter instance is pointing to an older version of the Parameter definition.
Version Label: This field displays the version label, if any, for this definition version.
Validation Status: This field displays the current validation status of the Parameter definition. If you are working directly in the definition in an Application Area or Domain and you have the necessary privileges, you can change the validation status by selecting Validation Supporting Information from the Actions drop-down list. If you are working in an instance of the Parameter in a Work Area, and you want to change the validation status of the definition, you must go to the definition. See Validating Objects and Outputs for further information.
Status: This field displays the installable status of the Load Set: Installable or Non Installable. See Installation Requirements for Each Object Type.
Variable Properties
This section displays the properties of the Variable that the Parameter definition belongs to.
Data Type: This field displays the data type of the Variable: VARCHAR2, NUMBER, or DATE.
Oracle Name: This field displays the Oracle name of the Variable to which the Parameter definition belongs.
Length: This field displays the length of VARHCAR2 or NUMBER type Variables.
SAS Name: This field displays the SAS name of the Variable.
SAS Label: This field displays the SAS label of the Variable.
SAS Format: This field displays the SAS format of the Variable.
Buttons
Update: Click the Update button to modify the Parameter instance. See Modifying a Parameter Instance.
- About Parameter Value Propagation
- Setting Up Value Propagation from the Source Parameter
- Setting Up Value Propagation from the Target Parameter
Within a Workflow or Report Set, you can set up automatic Parameter value propagation so that a Parameter contained in a Program instance in the Workflow or Report Set can receive its value automatically from another Parameter in the same Workflow or Report Set; either the output Parameter of another Program, or a Parameter created directly in the Workflow, Report Set, or Report Set Entry especially for this purpose.
Value propagation has two benefits:
Consistency. Value propagation ensures a consistent value among the Parameters you specify. For example, many Programs in a Report Set may have an input Parameter for the Study value. If the whole Report Set concerns only one study, you can set up value propagation from a special Value Propagation Parameter you define at the top Report Set level for this purpose, and all the study Parameters in the Report Set.
Ease of Submission. Value propagation makes it much easier to submit a Report Set or Workflow for submission because all Parameters defined as getting their value from another Parameter cannot be modified, and the person submitting the job is not required to enter a value for them.
You can set up value propagation in the definition of either the source or the target Parameter. If you want the value of a single Parameter to be propagated to multiple other Parameters, it is more efficient to set it up from the source Parameter.
The rules for defining value propagation are slightly different in Workflows and Report Sets.
Value Propagation in Workflows: Because a Workflow has a set execution order, you must always propagate Parameter values from Parameters whose value is entered or generated earlier during Workflow execution to Parameters that require a value later in Workflow execution. That is, the source Parameter must be either defined at the top level of the Workflow or be an input Parameter of a Program executed before the Programs containing the target Parameters to which its value is propagated.
Value Propagation in Report Sets: In Report Sets, the rules for value propagation are different depending on whether the source Parameter is defined directly in the Report Set/Report Set Entry, or is an output Parameter of a Program in a Report Set Entry:
Propagating values from Report Set or Report Set Entry Parameters. If you define a Parameter directly at the top level of the Report Set or in any Report Set Entry especially for the purpose of propagating its value to other Parameters in the Report Set or Report Set Entry, you must define the Parameter at the same level or a higher level from the Report Set Entries that contain the target Parameters.
Propagating values from Program output Parameters. Oracle LSH can adjust the execution order of a Report Set to accommodate the Parameter value propagation you define from the output Parameter of one Program to the input Parameter of another Program. You can define value propagation from a Program Parameter in a Report Set Entry that is displayed below a target Program Parameter's Report Set Entry. However, the system does not allow circular value propagation.
If you plan to use a triggered submission for a Workflow or Report Set, you must ensure that each Parameter contained in the Workflow or Report Set receives its value from a Parameter at the top level of the Workflow or Report Set or from an output Parameter generated by a Program within the Workflow or Report Set. For information on triggered submission, see Using Message-Triggered Submission from External Systems.
Parent topic: Setting Up Parameter Value Propagation
The following kinds of Parameters can serve as the source of the value in Parameter value propagation:
Program Output Parameters. You can use a Parameter value generated by one Program in a Report Set or Workflow to populate the value an input Parameter of one or more other Programs in the same Report Set or Workflow.
Report Set and Workflow Parameters. You can define Parameters especially for this purpose directly in a Report Set, Report Set Entry, or Workflow.
Report Set Overlay Template and Post-Processing Parameters. All Report Set Entries have the same set of predefined Parameters that the system uses to generate a single or multivolume PDF output. These Parameters are predefined to automatically pass their value to Parameters with the same name. You can explicitly set up value sharing for Post-Processing Parameters but not for Overlay Template Parameters; see Creating and Setting Report Set Parameters for further information.
You can set up value propagation either manually or automatically.
Setting Up Value Propagation Manually
To define value propagation from the source Parameter manually, do the following:
Parent topic: Setting Up Value Propagation from the Source Parameter
Setting Up Value Propagation Automatically
You can set up automatic value propagation to Parameters that may be added in the future to the Report Set or Workflow.
When you add a Program that contains a Parameter with the same name to the Workflow or Report Set, the system automatically sets up value propagation to it from this Parameter, and displays a message informing you that it has done so.
For Report Sets, the system sets up automatic value propagation only to Parameters that are in the direct flow below the value source Parameter.
For Workflows, the system sets up automatic value propagation only to Parameters that occur downstream in the execution flow.
To set this up, select the Automatically Pass Value to Parameters With Same Name check box.
Alternatively, if you prefer not to use automatic propagation or if you want to pass the value to Parameters with a different name, you can set up value propagation Malay. See Setting Up Value Propagation Manually.
This option is available only for Parameters contained in a Program that is part of a Report Set or Workflow, and for Parameters defined directly in a Report Set Entry. The Parameter's value must be passed to it by one of the following:
an output Parameter of a different Program in the same Report Set or Workflow
a Parameter created for this purpose in the Report Set or Workflow
in the case of post-processing Parameters in Report Sets, by the same predefined post-processing Parameter at the top of the Report Set or Report Set Entry
Do the following to set value propagation from the target Parameter:
The system uses the Parameter links you set up here to determine the execution order of Report Sets (which is not necessarily the same as the display order). The system prevents you from defining circular links.
Defining a set of standard Parameter Sets facilitates creating Parameter instances in Program and other executable instances and facilitates setting up Parameter value propagation in Report Sets and Workflows.
As soon as you add a Parameter to a Program, Report Set, or Workflow, behind the scenes, the system creates a Parameter Set definition and instance in that executable's definition. The Parameter you create really gets added to the Parameter Set definition and instance. You can never see a Parameter Set instance in the user interface, but a Parameter exists exclusively inside a Parameter Set. In addition, each executable can contain only a single Parameter Set. This is why you see the option of creating a Parameter using an existing Parameter Set only once.
When you are working in a Program, Report Set, or Workflow, the simplest way to create multiple Parameter instances is to create instances of all the Parameters in a Parameter Set at the same time. However, you must create logical Parameter Sets in Application Areas or Domains in order to use this functionality.
See Figure 6-1.
If you define the first Parameters by selecting a Parameter Set, then the system creates an instance of that Parameter Set in the executable definition. The Parameter Set definition remains in the Application Area or Domain. This has implications for modifying the Parameters in your executable, as follows:
If you have Modify privileges on the Parameter Set definition in the Application Area or Domain, you can make structural changes to the Parameter Set, but behind the scenes the system checks out the Parameter Set definition, creates a new version of it, and makes the same changes in the new version so that the Parameter Set definition remains consistent with the Parameter Set instance in the executable. The next time someone uses the same Parameter Set definition, he or she will see the modified version as the most current. Structural changes include adding and removing a Parameter and changing the source definition of any Parameter.
If you do not have Modify privileges on the Parameter Set definition in the Application Area or Domain, you cannot add or remove Parameters from your executable, or change the source definition of any Parameter, because the Parameter Set instance and definition must remain synchronized.
Solution 1: To avoid either of these situations and yet benefit from standard Parameter Sets, before you create Parameters in a Program or other executable, copy the Parameter Set definition in its Application Area or Domain and paste it into your local Application Area. Create Parameters in your executable from the local Parameter Set definition. You can then add and remove Parameters and the changes will affect only the local copy of the Parameter Set definition.
Solution 2: Create a version label on the version of the Parameter Set that is the correct, standard version. Always search for Parameter Sets with Version Labels that are not null, and use the correct version.
Explicitly Defining Parameter Sets
You may want to take the time to develop standard Parameter Sets based on standard Variables, logically grouped and meaningfully named.
To create a Parameter Set definition manually, do the following:
- In the Applications tab, navigate to the Application Area or Domain where you want to create the Parameter Set.
- Click Manage Definitions. The system opens the Maintain Application Area (or Domain) Library screen.
- From the Create drop-down list, select Parameter Set.
- Click Go. The system opens the Create Parameter Set Definition screen.
- Enter a Name and Description of the Parameter Set that will help other users determine whether to use this Parameter Set.
- Click Apply. The system opens the Parameter Set screen.
- Under Parameters at the bottom of the page, click Add. The system opens the Create Parameter screen.
- Add as many Parameters as necessary. See instructions at Creating a Parameter and Defining Parameter Details.
- To make the Parameter Set available for use, check it in.
Parent topic: Defining and Using Parameter Sets
You can define Source Code within a Program to generate a list of values for a Parameter, or to validate a user-entered value. You can use the same Source Code for both purposes.
When you search for Source Code to use for a Parameter's programmatic LOV or value validation, the system does not impose the normal security requirements; you can select any sharable Source Code from any Program, whether or not you have standard security access to the Program.
The source code you write must be in PL/SQL and must reference CDR_VALS_COLL, a predefined Oracle database object of type Collection whose structure is effectively the same as a table's, with rows and columns. CDR_VALS_COLL has two columns, one for position (row number in the table) and one for value (the value to derive for the list of values or validation). You must write source code that creates as many positions as necessary and populates each with an appropriate value.
If the source code generates only one value, the system assigns that value to the Parameter automatically.
CDR_VALS_COLL is effectively empty except when a Program populates it within the context of a particular user's session. Each user session "sees" its own collection only.
See example source code below.
To create a programmatically generated list of values for a Parameter, or to programmatically validate a Parameter value, do the following:
Create an Oracle LSH Program of type PL/SQL. See Creating a Program.
Add a Source Code definition to the PL/SQL Program. See Defining Source Code and Defining PL/SQL Programs.
In the Oracle Package field, enter the package name.
In the Oracle Procedure field, enter the function name. You are writing a function, not a procedure, but enter the function name in this field.
Add a source Table Descriptor for each Table instance your code will read from, if any. Map each Table Descriptor to the appropriate Table instance. See Defining Table Descriptors and Mapping Table Descriptors to Table Instances.
Enter your PL/SQL source code in the Source Code field.
As with other PL/SQL source code in Oracle LSH, you must include the package spec as well as the package body in your source code.
Be sure to use the same names for the package and function that you entered in the Oracle Package and Oracle Procedure fields.
The syntax in Example 6-1 is required verbatim up to the beginning of the function, except for the package and function names. See the examples for further information.
Apply your changes, check in the Program definition, and install the Program instance in its Work Area.
In the Parameter definition, specify the name of the Program and Source Code that contain the code that will generate the LOV or validate the Parameter value. See Defining Allowed Values and Setting Validation Rules.
Example 6-1 Simple Example
In this example, the source code creates two rows in the collection CDR_VALS_COLL. Position 1 has the value Yes and position 2 has the value No. This example shows the essential elements required in as simple a way as possible. However, you would not want to use this particular source code because you could accomplish the same thing much more simply by defining a static list of values with two values: Yes and No.
The package spec is the first five lines of code, up to the slash (/). The package name is LOV and the function name is returnValues. Except for these names, for which you can substitute any names you choose, all the code above the beginning of the actual function (at begin
) is required as is.
For each row in the collection the source code does the following in succession:
Creates the row itself by using an EXTEND command
Specifies the values for that row of the POSITION column
Specifies the values for that row of the VALUE column
Specifies that the function returns the value for position n
Example source code:
CREATE OR REPLACE package LOV as FUNCTION returnValues (pi_tParam IN cdr_parameter_obj_type ,pi_cParamColl IN cdr_parameter_coll) RETURN CDR_VALS_COLL; end LOV; / CREATE OR REPLACE package body LOV as FUNCTION returnValues (pi_tParam IN cdr_parameter_obj_type ,pi_cParamColl IN cdr_parameter_coll) RETURN CDR_VALS_COLL IS valuesRecord CDR_VAL_OBJ_TYPE := new CDR_VAL_OBJ_TYPE(NULL,NULL); LOVCollection CDR_VALS_COLL := CDR_VALS_COLL(); begin LOVCollection.EXTEND; valuesRecord.POSITION := 1; valuesRecord.VALUE := 'Yes'; LOVCollection(1) := valuesRecord; LOVCollection.EXTEND; valuesRecord.POSITION := 2; valuesRecord.VALUE := 'No'; LOVCollection(2) := valuesRecord; RETURN (LOVCollection); end returnValues; end LOV; /
Example 6-2 Pulling Column Values from a Table Instance
In the real world you would use a programmatically generated LOV to pull the current values of a column in an Oracle LSH Table instance that meet a certain set of criteria. In this case, you add a source Table Descriptor to the Program and map it to the Table instance whose Column values you want to read.
In your source code you write a SELECT statement and WHERE clause to describe the criteria for the values you want to retrieve. You then use the EXTEND command to create n rows in the collection, where n is the number of values retrieved, and populate each row with a POSITION value and a VALUE value.
Example 6-3 Pulling Values from an External System
You can pull values from a table in an external system if you include the necessary remote location connection information so that the system can read data in the external system.
The types of changes you are able to make to a Parameter definition or instance depend on many different interdependent factors:
Some Parameter properties belong to the Parameter instance, some to the Parameter definition, and others to the Variable. These three definitional layers may each belong to a different container, and you may have different privileges on each.
To modify a Parameter within a Program or other executable object, you must have Modify privileges on the Program or other executable object itself, and that object must be checked out.
A Parameter Set instance must remain structurally the same as its Parameter Set definition. If you add or remove Parameter instances from a Parameter Set instance, the system automatically creates a new version of the Parameter Set definition and removes them there as well. You must have Modify privileges on the Parameter Set definition or you cannot add or remove Parameter instances from the Parameter Set instance, or change the source Parameter definition for Parameter instances within the Parameter Set instance.
If you are working in an Execution Setup, you can make very few changes to Parameters.
You can make the following changes in the following locations:
Parameter Definition: Parameter definitions are located in two places: contained directly in an Application Area or contained directly in a Domain. In either of these locations, if you have the required privileges, you can do the following:
Update the properties of the Parameter definition itself.
Select a different source definition Variable for the Parameter definition.
Check out the source definition Variable through the Parameter definition, then go to the Variable and modify it. The Parameter definition references the new version of the Variable.
Parameter Instance in a Parameter Set Definition: If you have the necessary privileges, you can go to a Parameter Set definition contained directly in a Domain or Application Area and modify the Parameter instances it contains. You can make the following changes:
If you have the necessary privileges on the Parameter definition, you check out the Parameter definition through the Parameter instance, the go to the Parameter definition and modify it. The Parameter instance references the new version of the Parameter definition.
Using the Update button, you can modify the properties belonging to the Parameter instance.
Parameter Instance in a Parameter Set Instance in an Executable Object: Parameter Set instances are located in Programs and other executables and in Execution Setups. The following applies to Parameter Set instances that are located anywhere except in an Execution Setup:
If you created the Parameter Set instance in the executable by creating Parameters based on an existing Parameter Set, the Parameter Set definition is located in an Application Area or Domain. In this case:
You cannot check out the Parameter definition from a Parameter instance.
You can select a different source definition Parameter for the Parameter instance only if you have Modify privileges on the Parameter Set definition. This is a structural change, and the system automatically checks out the Parameter Set definition and creates a new version of it with the change.
Load Sets, Data Marts, Business Areas, and some Program types have predefined Parameter instances whose source definition Parameters are located in Adapter Areas. You should not modify these Parameters, and the administrator should set up security so that it is not possible to modify the Parameter definitions.
If you created the Parameter Set instance in the executable by creating one Parameter at a time—either defining a new Parameter definition and instance, or creating an instance of an existing Parameter—then both the Parameter Set definition and the Parameter Set instance are located in the same executable. In this case:
You can check out the source definition Parameter from the Parameter instance and make changes as necessary.
Any structural changes you make—adding or removing Parameters, or selecting a different source definition Parameter for an instance—are automatically applied to the Parameter Set definition as well as the Parameter Set instance.
Parameter Instance in a Parameter Set Instance in an Execution Setup: You cannot update the Parameter instance or check out and modify the source definition Parameter from a Parameter instance contained in an Execution Setup.
To modify a Parameter instance in a Program or other executable, do the following:
Parent topic: Modifying Parameters
Modifying a Parameter Definition
If you have the necessary privileges, you can modify a Parameter definition directly in the Application Area or Domain, or through an instance of the Parameter in a Parameter Set in an Application Area or Domain.
Never change anything in a Parameter definition from a Load Set, Data Mart, and Business Area. If you do, the adapter you used to create the Load Set, Data Mart, or Business Area, becomes invalid and either you cannot create any more objects of that adapter type, or the objects you create do not work.
- Modifying a Parameter Definition Directly in a Domain or Application Area
- Modifying a Parameter Definition through a Parameter Set
To modify a Parameter definition directly in a Domain or Application Area, do the following:
Navigate to the Domain or Application Area in the Applications tab.
Click the Manage Definitions icon. The system opens the Maintain Library screen.
Click the Parameter node (+). The system displays all the Parameters in the Application Area library.
Click the hyperlink of the Parameter you want to modify. The system opens the Parameter Definition screen.
Click Check Out. The system checks out the Parameter and creates a new version of it.
Click Update. The system makes all the fields enterable.
Modify the settings as necessary. For an explanation of each setting, see Create a New Parameter Definition and Instance and Defining Parameter Details.
If you need to change the attributes that belong to the Variable (Data Type, Length, and, for Number types, Precision) you can select a different Variable in the Definition field or, if you have Modify privileges on the source definition Variable, you can check it out through the Parameter definition and modify it as necessary. The Parameter definition references the new version of the Variable.
Click Apply. The system saves your changes.
Parent topic: Modifying a Parameter Definition
When you modify a Parameter definition through an instance of it in a Parameter Set, the instance automatically points to the new version of the Parameter definition. To modify a Parameter definition through an instance of it in a Parameter Set, do the following:
- Navigate to the Domain or Application Area in the Applications tab.
- Click the Manage Definitions icon. The system opens the Maintain Library screen.
- Click the Parameter Set node (+). The system displays all the Parameter Sets in the Application Area library.
- Click the hyperlink of the Parameter Set that contains the Parameter you want to modify. The system opens the Parameter Set definition screen.
- Click Check Out. The system checks out the Parameter Set and creates a new version of it.
- Click the hyperlink of the Parameter you want to modify. The system opens the Parameter instance screen.
- In the Parameter Definition section in the lower part of the screen, click Check Out. The system opens the Check Out screen.
- Enter the reason you are checking out the Parameter definition in the Comment field and click Apply. The system returns you to the Parameter instance screen.
- Click the hyperlink to the Parameter definition in the Definition field in the Instance Properties section at the top of the screen. The system opens the Parameter Definition screen.
- Click Update. The system makes fields enterable.
- Modify the settings as necessary. For an explanation of each setting,
- Click Apply. The system saves your changes.
