6 Validating Objects and Outputs
This section contains information on the following topics:
About Validation
Regulatory agencies require that you validate the data you submit as part of your drug approval application. The Oracle Life Sciences Data Hub (Oracle LSH) includes tools to help you to do this, including validation statuses, validation supporting information, and coversheets that include validation information for every report you create.
Oracle LSH cannot certify the quality of the data that you load into Oracle LSH. It is your responsibility to validate data in your source data system(s). However, Oracle LSH can help you certify that Oracle LSH handled data in a valid manner. If you can demonstrate that your source data is valid, and that Oracle LSH manipulated your source data in a valid manner, then data reported or sent out of Oracle LSH must be valid. Each time you generate a report on Oracle LSH data, you can generate a report coversheet that includes the validation status of every defined object that affected the source data for the report, including Tables, Programs, and Load Sets, since the data entered Oracle LSH.
In addition, Oracle LSH allows you to manually validate Program outputs using the same methods you do now. In the context of a Report Set, where different sections may be at different stages of validation at any one time, the system reuses existing, validated outputs as long as any requested outputs would be duplicates of the validated one. Therefore you can continue to develop some sections of a Report Set, changing Parameter values and using new Program versions, and reuse the outputs of other sections as long as your changes do not affect those sections.
Oracle LSH keeps all defined objects under version control. Each version of each object has a validation status. Oracle LSH ships with predefined validation statuses that represent different stages in an object's life cycle: Development, Quality Control, Production, and Retired.
By default, all new objects and all new versions of objects have a validation status of Development. Oracle LSH does not enforce any conditions for promotion of an object to Quality Control or Production. You should develop the standards you require for promotion. Oracle LSH does enforce rules based on objects' validation status and on the interaction of a Work Area's validation status and its Usage Intent attribute value (see Work Area Usage Intent and Validation Status). These rules promote using validation status to create separate, clean, Quality Control and Production environments.
Oracle LSH allows you to link documents and outputs with objects to demonstrate that they meet a validation requirement. For example, you can store documents such as Functional Requirements, Test Requirements, or Test Cases with a Program or Report Set, or an output such as a log file or generated report to demonstrate that the Program or Report Set was successfully executed. See Validation Supporting Information for further information.
You can begin application development in Oracle LSH before arriving at your standards for definitional object validation, and it is possible to use Oracle LSH without ever using another validation status beyond Development. However, if you plan to submit data to a regulatory agency, you should not go into production until you have developed standards and validated all objects that operate on or store production clinical data.
All objects that are contained directly in a Domain, Application Area, or Work Area have a validation status.
Parent topic: Validating Objects and Outputs
Validation Statuses
Oracle LSH allows you to apply the following validation statuses fo all objects that require validation: Development, Quality Control, Production, and Retired.
Development
Oracle LSH automatically gives all new objects, and new object versions, a validation status of Development.
Organizational objects (Domains and Application Areas) have a permanent validation status of Development, which is never visible in the user interface.
Parent topic: Validation Statuses
Quality Control
This validation status is intended to be used for objects that have already undergone informal testing by a programmer and are currently being formally tested, perhaps by a separate group of people, such as Quality Control engineers.
It is your responsibility to develop standards for the use of the Quality Control (QC) validation status.
Production
This status is intended for objects that have been thoroughly tested and certified as being ready for use with production clinical data suitable for preparatory to submission to a regulatory agency.
Oracle LSH protects data in a Work Area with a validation status of Production by preventing the use of Work Area installation modes that would delete data in the Work Area's tables.
You must develop standards for the use of the Production validation status.
Retired
This validation status is intended for objects you no longer wish to use.
Retired Object Rules
Oracle LSH enforces the following rules on objects with a validation status of Retired:
- You cannot create an instance of a Retired object definition. (However, existing instances of a definition whose status is changed to Retired can still have an active validation status and function as before.)
- You cannot modify an existing object instance to point to an object definition whose validation status is Retired.
- Executable object instances whose validation status is set to Retired cannot be run.
If you decide that you want to use a retired object, there are three ways to do so:
- If you have the necessary privileges, you can reactivate the object, setting its validation status back to whatever it was immediately before retirement.
- Copy the retired object. The system sets the validation status of the new object to Development.
- Create a new version of an object by checking it out (object definitions only).
Parent topic: Retired
Retired Work Area Rules
Retire the Production Work Area for a trial when you close the trial. Oracle LSH enforces the following behavior for Work Areas whose validation status is set to Retired:
- No object contained in a Retired Work Area can be run.
- Objects contained in a Retired Work Area retain their current validation status when the Work Area is set to Retired.
- When you clone a Retired Work Area, the validation status of the clone is also set to Retired. The object instances contained in the original Retired Work Area retain the same validation status in the clone.
- When you clone a Retired Work Area, any Retired object instances contained in the original Work Area are cloned along with all the other object instances.
Validation-Related Security
Oracle LSH includes the following validation-related operations on object types:
- Modify Validation Status QC. This privilege is required to set an object's validation status to Quality Control. Users with this privilege can also set the status to Retired.
- Modify Validation Production. This privilege is required to set an object's validation status to Production. Users with this privilege can also set the status to Retired.
- Manage Supporting Information. This privilege is required to link documents and outputs to an object as Validation Supporting Information.
In addition, Work Areas have a validation-related operation called Install Qualify Submit . No executables can be run in a Work Area until the Work Area's validation status is equal to or greater than its usage intent value, except by users with the special Install Qualify Submit privilege on the Work Area. This is to allow testing of the Work Area before making it generally available for use. See Work Area Usage Intent and Validation Status for further information.
Oracle LSH allows you to link an object to two types of supporting information for the purpose of documenting that one of your internal validation requirements has been met: Supporting Documents and Supporting Outputs.
Oracle LSH does not enforce the use of supporting information. It is possible to promote an object to a higher validation status even if the object is not linked to the supporting information you require in your standard operating procedure (SOP).
You can upload documents to Oracle LSH and create a link from an object to the document. Oracle LSH keeps each document under version control, creating a new version number each time the document is uploaded. Oracle LSH never deletes a supporting document.
Users with the Manage Supporting Information privilege can link objects to supporting documents and outputs.
For example, you could store the following types of documents as validation supporting information for an object:
- a requirements document stating the purpose of the object and specifying functional requirements
- a design document that specifies the way the functional requirements will be achieved technically
- a test requirements document listing the functionality that must be formally tested
- actual test cases to be used in testing the object
- test results
The examples given above might all be appropriate requirements for promotion from Development to Quality Control, and require the last for promotion from QC to Production.
Parent topic: Validation Supporting Information
Supporting Outputs
You can also create a link between an object and a particular output. For example, to demonstrate that you successfully ran a Program, you could create a link to one or both of the following outputs of the successful job:
- a report generated by the Program
- the log file of the successful Program execution
Supporting outputs may be appropriate requirements for promotion to Quality Control and Production status.
Output Coversheets
You can generate a summary or detailed coversheet for any output in Oracle LSH that lists the validation status of the defined objects that handle the data in the output.
- The summary coversheet gives the validation status of the executable object that generated the output and of each Table instance from which the executable read data.
- The detailed coversheet gives the validation status of each executable object and Table instance that handled the data from the time it was loaded into Oracle LSH to the executable that produced the output. The system examines the immediate source Table instances, then the executables that wrote data to those Table instances, then the Table instances that those executables read data from, and so on to the Load Sets that loaded data into Oracle LSH.
If you have developed good standard operating procedures using the tools provided by Oracle LSH for testing and validating defined objects to ensure that they do not corrupt data, and followed those procedures, then data that was valid when loaded into Oracle LSH should remain valid in Oracle LSH.
Cascading Validation
Whenever you change an object's validation status to a higher status, the system attempts to make the same validation upgrade to any objects contained by the object you are explicitly upgrading. In addition, if you upgrade an object instance to a status higher than the status of its underlying definition, the system attempts to upgrade the validation status of the definition as well. For example:
- If you promote a Workflow definition from Development to QC, the system attempts to upgrade all the object instances owned by the Workflow, such as Programs and Load Sets. The system also attempts to upgrade the underlying definition of each instance.
- If you promote a Work Area from QC to Production, the system attempts to upgrade all the object instances contained in the Work Area, and all the definitions on which they are based.
If the system is unable to upgrade the status of all affected objects, the validation fails. The system is unable to upgrade objects in the following circumstances:
- The user performing the upgrade does not have the Modify Validation Status privilege on one of the other objects that must be upgraded as part of the operation.
- One of the objects that must be upgraded is checked out by a different user.
An upgrade is changing validation status from Development to either Quality Control or Production, or from Quality Control to Production.
Downgrades include changing validation status from Production to any other status, changing from Quality Control to Development, and changing from any other status to Retired. There is no cascading of validation downgrades.
Work Areas have a special attribute called Usage Intent whose allowed values are Development, Quality Control, and Production. Oracle LSH enforces the following rules based on a Work Area's usage intent value and the validation status of the Work Area and all its object instances:
- To be installed in a Work Area, object instances must have a validation status equal to or greater than the usage intent of the Work Area.
- The Work Area cannot be promoted to a validation status higher than the validation status of any of its object instances.
- No executables can be run in a Work Area until the Work Area's validation status is equal to or greater than its usage intent value, except by users with the special Install Qualify Submit privilege on the Work Area. This is to allow testing of the Work Area before making it generally available for use.
- Full installation and Table instance replacement during partial installation are not allowed in Work Areas with a usage intent of Production. This is to protect production data from deletion.
These rules support the following intended Work Area usage:
Validation Rules
The system enforces the following rules based on objects' validation status:
- You can change an object's validation status only when it is checked in. If the
object is not checked in, the system tries to checks it in. If another user has
checked it out, you cannot change the validation status.
Changing the validation status of a checked-in object does not change the version number of the object.
- You cannot promote an object instance to a validation status higher than its
underlying object definition.
For example, if you create an instance of a Program definition whose validation status is Quality Control, you can promote the instance to a validation status of Quality Control, but you cannot promote it to Production until the definition has been promoted to Production. However, the system attempts to promote the definition to Production when you promote the instance, and if you have the necessary privileges on the definition, and if the definition is not checked out by a different user, the promotion succeeds.
- Validation status is version-specific. Each time you create a new version of an object by checking it out (including checking out a definition through an instance) the system automatically gives the new version a validation status of Development. The system does not change the validation status of any existing versions.
- When you copy an object, the validation status of the copy is set to Development no matter what the validation status of the original is.
- You cannot run an Execution Setup whose validation status is less than the validation status of its owning object instance unless you have the IQ Submit security privilege on the Execution Setup.
status of any of its object instances. However, if you try to promote a Work Area to
a status above that of any of its objects, you have the opportunity to promote all
the object instances and their underlying definition versions to the same status in
a cascade operation.
The cascade validation fails if a different user has checked out any of the object definitions in need of promotion.
- No executables can be run in a Work Area until the Work Area's validation status is equal to or greater than its usage intent value, except by users with the special Install Qualify Submit privilege on the Work Area. This is to allow testing of the Work Area before making generally available for use.
- Full installation and the Replace operation on Table instances in partial installation are not allowed in Work Areas with a usage intent of Production. This is to protect production data from deletion.
- You cannot remove a Table instance whose validation status is Production from a Work Area of any usage intent.
Design Decision Summary
You should set standards for promotion to the Quality Control and Production validation statuses for definitions and instances of Tables, Programs, Load Sets, Report Sets, Workflows, Data Marts, and Business Areas. Oracle LSH automatically promotes component objects such as Parameters, Notifications, and Overlay Templates when you promote their containing object. However, you may also want to explicitly validate these object definitions and move them to a Domain for reuse.
If you are using object subtypes, you can set different validation requirements for different subtypes of the same object type.
Oracle LSH provides two types of requirements to use: Supporting Information and Security. You can create additional required operating procedures if you so choose.
Specify documents and/or outputs that you require for promotion to each validation status. Write and enforce your policy as you would any other company standard operating procedure (SOP). Oracle LSH stores supporting documents and links both documents and outputs to objects as Validation Supporting Information.
Parent topic: Design Decision Summary
Considerations
Oracle LSH does not enforce any system behavior in relation to Validation Supporting Information. However, the Data Validation Report lists all documents and outputs linked to an object as Validation Supporting Information.
Parent topic: Supporting Information
Security
Oracle LSH supplies the operations Modify Validation Status QC, Modify Validation Status Production, and Manage Supporting Information operation on all object types and subtypes. You must define one or more roles with each of these operations on object subtypes, assign the roles to user groups, and assign users to the roles within user groups.
Restrictions
Users with a role that has the Modify Validation Status QC operation can promote an object from Development to Quality Control. They can also downgrade any validation status except Production, provided that Validation Rules are not violated.
Users with a role that has the Modify Validation Status Production operation can promote an object from QC to Production as well as from Development to QC. They can also downgrade any validation status, provided that Validation Rules are not violated.
Parent topic: Security
Considerations
You can assign both operations to the same role or to different roles. If you assign them to different roles, you can still assign both roles to the same user. However, if you always assign different users to each role, you can demonstrate that more than one person was involved in validating an object.
You can use the same roles for all object types and subtypes or differentiate them. For example, you might want to use a different role for promoting Load Sets than for promoting Report Sets.
