5 Designing a Classification System for Searching and Browsing
This section includes information on the following topics:
About Classification
A typical clinical trial requires the development of many Programs and other defined objects, and repeated executions of each one, so that by the end of the trial there are large numbers of objects and outputs such as reports.
The Oracle Life Sciences Data Hub (Oracle LSH) classification system allows you to organize these objects and outputs by classifying, or labeling, them in ways that reflect your business or clinical organization, or that identify any characteristic you choose. Oracle LSH uses classifications to help users find outputs and defined objects in two ways: Browsing and Searching.
Browsing
Oracle LSH uses the classification system you set up to create a customized user interface in the Reports tab for both the Outputs and Visualizations subtabs.
You can create hierarchies of categories that are logically related to one another, so that Oracle LSH displays outputs within that hierarchical structure, like the folder structure on a PC.
For example, if you have multiple projects, multiple studies in each project, and multiple sites in each study, you can create a hierarchy with three levels: Project, Study, and Site. Enter all your actual project names in the Project level, all study names in the Study level, and all site names in the Site level, noting which sites are part of which studies and which studies are part of which projects.
In the Reports tab, Oracle LSH displays a folder for each project, labeled with the project name. Each project folder contains a folder for each of the studies in that project as well as all reports classified to that project as a whole. Each study folder contains a folder for each of the sites in that study, as well as all reports classified to that study as a whole. Each site folder contains all reports classified to that site.
Alternatively, within each study you could have folders for reports on demography and adverse events reports, for example.
Oracle LSH executable objects can produce outputs as follows: Programs can produce reports; Report Sets generate sets of reports; Data Marts produce files in text, SAS data sets or transport files, or Oracle Export format containing large amounts of data; and SAS and text Load Sets may produce the text or SAS file loaded as an output. All executables can also produce log files, but these are not displayed in the Reports screen directly; they are available as a link from the main screen for each output.Parent topic: About Classification
Searching
Oracle LSH allows users to search for outputs and defined objects based on classifications, as well as other criteria. Definers need to search for existing object definitions they can reuse, either exactly as they are or with modifications. Consumers need to find reports and other outputs that contain information they need. They may also need to find submission forms to generate outputs on new data, or to load data into Oracle LSH.
The Simple Search feature allows using a single classification value as a search criterion. Advanced Search allow using multiple classification values.
Classification Setup
To implement Oracle LSH classification, you must do the following:
- Define at least one classification hierarchy that contains information relevant to your business or clinical organization—any information that characterizes Oracle LSH objects in a way that might help a user find an object in Oracle LSH (see Defining Classification Hierarchies).
- Define classification values at each level of each hierarchy, with relations between values; for example, in the Project > Study > Site hierarchy, put all project names in the Project level, all study names in the Study level, each with a relation to its project, and all site names on the Site level, each with a relation to its study or studies (see Defining Classification Values).
- Assign classification hierarchy levels to object subtypes, specifying whether the classification to each level is mandatory for objects of that subtype and whether classification by inheritance from the owning object is allowed (see Assigning Classification Levels to Object Subtypes).
- Assign classification values to objects, starting with Domains, Application Areas and Work Areas. These classifications can be automatically inherited by objects within these containers if you allow classification by inheritance for their object subtypes. Definers can change inherited classifications for individual objects as necessary. The new classification applies to all versions of the object and carries forward to new versions unless a new version is explicitly reclassified.
Instructions are included in "Setting Up the Classification System" in the Oracle Life Sciences Data Hub System Administrator's Guide.
You should design your classification system in conjunction with designing your organizational structure and security system:
- Organizational Structure. When you choose to use classification by
inheritance, objects automatically receive classification value(s) for a particular
hierarchy level from their container. Take advantage of this functionality by
designing an organizational structure that reflects the way you want outputs to be
displayed on screen.
You may want to make classifications inherited for all object types except the organizational objects (Domains, Application Areas, and Work Areas.)
Outputs can inherit classifications from the executable object instance that generates them, which in turn can inherit classifications from the Work Area, which in turn can inherit classifications from the Application Area (see Object Ownership). Therefore, if you use the Project > Study > Site hierarchy, classify an Application Area to Study ABC123, and allow inheritance for the Study level for all object subtypes, all reports generated within the Application Area will be classified to Study ABC123 and displayed in the Study ABC123 folder on the Reports screen.
- Subtypes and the Security System. Each object type has one predefined subtype
called Default. You can create additional subtypes if you choose to, but this is
optional. For example, if you plan to store and analyze financial information in
Oracle LSH, you could create a subtype called Financial. When you set up your
classification system, you can allow or require that objects of a particular subtype
have be classified at a particular hierarchy level. Financial object subtypes might
be classified to the same or different hierarchy levels as Default or Clinical
object subtypes; for example, you might have a financial hierarchy with levels
called Fiscal Year > Quarter.
When you set up your security system, you assign roles to operations on object subtypes. If you plan to store and report on financial information in Oracle LSH, you probably want different people to see financial reports and clinical reports. If you create a Financial subtype, you can assign different roles to the View operation on Financial outputs than to the View operation on Clinical outputs. Therefore, take both your classification and security systems into consideration when deciding whether to use subtypes; see Object Subtypes.
As you begin the design process, focus first on the hierarchies you will use to display outputs in the Reports window. These hierarchies are also available for use in searching. Next, if you wish, develop additional hierarchies for use in searching only (see Keyword Hierarchies).
You must define at least one hierarchy to create a user interface for browsing for outputs. You can define any number of additional multi- and single-level hierarchies.
Multilevel Hierarchies
Multilevel classification hierarchies consist of ranked, logically related levels with a strictly ordered parent/child relationship, represented in a linear sequence such as Project > Study > Site > Patient. A parent level can have only one child level, and a child level can have only one parent level.
Oracle LSH uses multilevel hierarchies to display outputs on the Reports screen. You can also use multilevel hierarchies to search for outputs and defined objects.
Parent topic: Defining Classification Hierarchies
Single-Level "Hierarchies"
Some types of information may not be hierarchical by nature. In this case, you can still define a "hierarchy," but it can consist of a single level. In searches, single-level hierarchies function as a list of values.
Keyword Hierarchies
You can designate a single-level hierarchy as a keyword hierarchy. Oracle LSH does not use keyword hierarchies to display outputs or submission forms for browsing, but does allow using them to search for outputs and defined objects. Using Advanced Search, users can search on more than one hierarchy value at a time. Use keyword hierarchies to help users add search criteria to narrow their search results and find the object definitions and outputs they need. You can create keyword hierarchies especially for a particular kind of object or output.
For example, create several keyword hierarchies to use for Program definitions, such as technology types (SAS, PL/SQL, and Oracle Reports), the basic function of the Program (transforming, reporting, or both), and the tables the Program reads from (Demography, Adverse Events, Concomitant Medications, and so on). When a Definer searches for a Program definition, he or she can use any number of these keywords as search criteria. See Classification Hierarchies for Use in Searching Only for more examples.
Parent topic: Single-Level "Hierarchies"
Nonkeyword Single-Level Hierarchies
You may want to put outputs and submission forms into several categories that are not hierarchical and use them for browsing on screen. In this case, define a hierarchy with a single level and do not designate it a keyword hierarchy.
Defining Hierarchy Levels
You must define at least one hierarchy level for each classification hierarchy. If the hierarchy has more than one level, each level must be logically related so that the topmost level contains the most general values and the bottommost level contains the most specific ones.
You must make the following design decisions for each hierarchy level:
- Set the Allow Classification Flag. If set to Yes, this level can be assigned
to object subtypes, which allows objects of that subtype to be classified to values
contained in this hierarchy level. (When you define object subtypes, you specify
whether the hierarchy level is allowed, not allowed, or required for each particular
object subtype; see Assign Hierarchy Levels to Object Subtypes.) The default setting is Yes.
If set to No, the hierarchy level still exists and serves to organize classification values in the levels below. For example, you might want to create a Project > Study > Site > Patient hierarchy even if you do not generate reports that are specific to a single site. In this case, you can set the Allow Classification Flag to No for the Site level. In the Reports screen, folders for each site are displayed within each Study folder. Each site folder contains a folder for each patient. Any patient-specific reports, such as for a serious adverse event, are contained in a patient's' folder.
- Set Term Uniqueness. This setting determines the way Oracle LSH enforces the
uniqueness requirement for classification values in the level. This attribute has
these possible settings:
- Unique Within Level. Each classification value contained
in this level must be unique relative to all other classification values in
the level.
For example, there can be only one Site called General Hospital in the Site level. Because each child classification value can have only one parent value, General Hospital can be associated with only one study.
- Unique Within Parent. Each classification value
contained in this level must be unique relative to the other classification
values in the level that are related to the same parent classification
value.
In this case, if the site General Hospital is participating in more than one study, the classification value General Hospital can appear multiple times in the Site level, if it is associated with a different study each time (see Figure 5-1).
the level.
A classification value is the actual name used in your organization for a particular item in the category represented by the classification level; for example, the name of a particular project in the Project level.
In a multilevel hierarchy, classification values have relations to logically related classification values in the levels above and below their level. Each classification value must have exactly one related term in the level above and may have zero or more related terms in the level below.
In a single-level hierarchy, classification values do not have defined relations with any other classification values. They may or may not be logically related to each other.
Figure 5-1 Example of Related Classification Values within a Multilevel Hierarchy Structure
Description of "Figure 5-1 Example of Related Classification Values within a Multilevel Hierarchy Structure"
In the example above, the Term Uniqueness attribute of the Site level is set to Within Parent so that the same site can appear in the Site level more than once, related to more than one study. In the example, both General Hospital and Grace Hospital appear twice, for two different studies.
This section includes the following topics:
About Subtypes and Classification
Oracle LSH ships with predefined object types, including Program definitions, Program instances, Table definitions and instances, Report Set definitions and instances, and so on (for a complete list, see Object Types with Operations).
Each time a Definer creates an object, he or she must select a subtype for it. One subtype (called "Default") is predefined for every object type. If you choose to, you can create additional subtypes for any object type. You must assign at least one classification level to each object subtype, including the default subtype.
You assign classification hierarchy levels—for example, Study in the Project > Study > Site hierarchy—to object subtypes. Definers can then classify objects of that subtype to that hierarchy level and find objects of that subtype by searching on that level's classification values. In the case of subtypes of Outputs and of Execution Setups, which become submission forms, the system displays them in the Reports screen by their classification values for that hierarchy level.
You may want to define subtypes specifically for the purpose of assigning different classification hierarchy levels to objects of the same type. For example, you could create a classification hierarchy Fiscal Year > Quarter and assign its levels to Outputs of subtype Financial but not Clinical. See Object Subtypes.
Parent topic: Assigning Classification Levels to Object Subtypes
Making a Classification Level Mandatory
For each classification hierarchy level you assign to an object subtype, you must set the Mandatory flag to Yes or No.
Mandatory
If you set it to Yes, then all objects created using that subtype must have at least one classification value for the hierarchy level. For example, if you assign the level Project > Study to the Clinical Output subtype as Mandatory, all Clinical outputs must be classified to at least one study name.
The Oracle LSH Reports tab display is arranged hierarchically by classification values. If an output is not classified at all, it does not appear in the Reports tab. Therefore you may want to make at least one classification level mandatory for outputs you want to see in the Reports screen. If you have set up an organizational structure and classification system to work together, you can set a value for Study, for example, at the Work Area level and make the Study level value inherited by all object instances and outputs, so that outputs automatically receive the Study value set for their Work Area (see Allowing Classification by Inheritance).
If an output is not classified, you can still find it by searching on its name or other attributes.Parent topic: Making a Classification Level Mandatory
Optional
If you set the Mandatory flag to No, classifications to that hierarchy level are optional for objects of that subtype. If you assign classification values of that hierarchy level to an object of that subtype, the system allows using them in searching and, if the object is an output or submission form, displays it on screen in a folder named for the classification value. For example, if a report is classified to Wonderdrug 856 > WD856 Study 01, in the Outputs window the report is contained in the WD856 Study 01 folder, which is under the Wonderdrug 856 folder.
If you do not assign any classification values of that hierarchy level to an object of that subtype, the only effect is that those values are not available for use in searching and browsing.
In general, assigning hierarchy levels as optional gives you flexibility, does not cause problems, and may be necessary. For example, some outputs may pertain to a particular study, and others may pertain to a project as a whole. If you assign both the Project and Study levels to Output subtypes, the Definer can select the level that is appropriate for a particular output.
However, if you create a hierarchy that applies only to a limited number of object types, do not assign its levels to other object types. For example, you could create a single-level hierarchy called Technology Type for Programs with SAS, PL/SQL, and Oracle Reports as values, so that you could search for Programs of a particular object type. This hierarchy has no relevance to Tables or Outputs, for example.
When you assign a hierarchy level to a subtype and make it optional, the level appears as an option in a drop-down list when you are classifying a particular object of that subtype and when you are searching for one. It makes sense not to add an item to this list that does not apply to the object type. For example, it is better not to assign the Technology Type hierarchy level to Tables or Outputs.
For each classification hierarchy level you assign to an object subtype, you can set the Ref Allowed flag to either Yes or No.
Reference Allowed
If you set the flag to Yes, objects of that subtype can inherit their classification values for that hierarchy level from their container: the Domain, Application Area, Work Area, Report Set, or Workflow where they are located.
You must also assign the same hierarchy level to the parent object subtype.
To make this happen automatically when each object of this subtype is created, you must also set the default classification for the hierarchy level to Inherited (see Setting a Default Classification).
Allowing classification by inheritance can save time during object definition, especially if your organizational structure and classification systems are compatible. For example, if your Application Areas contain applications for a single study, you can assign the hierarchy level Project > Study to Application Areas and to Programs, Tables, Report Sets, and the other primary objects that are contained directly in Application Areas. Then when you classify a particular Application Area to a particular study, such as Project01 > Study01, all the objects contained within it are automatically classified to Project01 > Study01 as well.
In addition, if you change the classification of the Application Area, all the objects it contains for which inheritance classification is allowed are automatically reclassified to the new value for the same hierarchy level. For example, if you copy the Application Area classified to Project01 > Study01 (with all the objects it contains) to serve as the basis for the Application Area for Study02, and change the classification of the copy to Project01 > Study02, the objects it contains are automatically reclassified to Project01 > Study 02.
You can define several levels of classification by reference. For example,
Figure 5-2 Example of Classification by Inheritance
Description of "Figure 5-2 Example of Classification by Inheritance"
Parent topic: Allowing Classification by Inheritance
Classification by Inheritance Not Allowed
If you set the Ref Allowed flag to No, Definers can still manually classify objects of that subtype to that hierarchy level. If you define the level as Mandatory for the subtype, Definers must classify them manually to the hierarchy level.
Overriding Inherited Classifications
Even if you define an object subtype as having classification by inheritance for a particular hierarchy level, Definers can override that classification for any object of that subtype.
Definers can also change the classification back to a classification by inheritance. The object then is automatically classified to its container's classification value for the hierarchy level.
Top-level Domains cannot have inherited classifications. To enforce this at the subtype level, set Reference Allowed to No for Domains. If you are using nested Domains and you want child Domains to be able to inherit classification values from their parent Domain, you may want to create an additional subtype for Domains. For example, create subtype Top-Level Domain where no referencing is allowed, and subtype Child Domain where referencing is allowed for all classification levels.Parent topic: Allowing Classification by Inheritance
When you assign a classification hierarchy level to an object subtype, you can set one or more default classification values for objects of that subtype. Whatever value you set as the default classification is applied to every object created of this subtype. You can override the default classification for an object at any time.
Default classifications for subtypes are not required. You can set two types of default classifications:
- Default classification by inheritance
- Default classification to a specific value
- Setting the Default to Inherited
- Setting the Default to a Specific Value
- Leaving the Default Setting Blank
If you set the default classification to Inherited, objects of the subtype automatically receive the same classification for this hierarchy level as their container object. See Allowing Classification by Inheritance.
Parent topic: Setting a Default Classification
You can enter one or more specific values for each hierarchy level assigned to a subtype. Every object created as that subtype then is automatically classified the same way.
For example, if the classification level Project > Study is assigned to the subtype, you could set values such as Project01 > Study01 and Project01 > Study02.
This approach is not recommended because the point of classifying objects is to differentiate them in an appropriate way.
If you do not assign a default value for a hierarchy level, objects of the subtype will be created without a value at that level. You can add a classification to a particular object at any time.
If the hierarchy level is defined as Mandatory for the subtype but has no default value, you must enter a value manually when you create an object of the subtype.
Classifying Outputs
Outputs such as reports receive their classification from the Planned Output in the definition of the Program or other executable that generates them.
If the Planned Output's classification value for a particular level is explicitly assigned, to a particular value, the actual output receives that value for that level. However, since the Planned Output is part of the Program (or other executable) definition, and you may want to reuse the definition by creating instances of it in multiple Work Areas where that value may not be appropriate, this may not be a good way to classify the output.
Alternatively, you can set the Planned Output definition's classification value for a particular level to Inherited. The actual output then receives its value for that level from the Execution Setup used to submit the job that produces the output.
Therefore, when you set up classification levels for object subtypes, you must be sure to include the same levels for corresponding subtypes of both Outputs and Execution Setups.
Execution Setups inherit classification values from their executable instance (for example, the Program instance that owns the Execution Setup). Executable instances inherit their classification values from their Work Area.
Outputs can also be classified by a parameter value entered when the job is submitted or generated by the job. You can define a Parameter with a list of values that includes the term values in a classification hierarchy level. Further information is available in the "Classifying Outputs" section in the chapter on common development tasks of the Oracle Life Sciences Data Hub Application Developer's Guide.
In addition, users with the necessary privileges can reclassify an output after it has been generated.
Classification Example
If you set up your organization and security systems as described in the previous chapters, you could set up classification as described in this section.
Figure 5-3 Example Organizational Structure
Description of "Figure 5-3 Example Organizational Structure"
In this example, there is a Domain for every project, as well as a Domain for companywide reports and a Domain for company standard definitions. Within each project Domain there is an Application Area for every study in that project and another Application Area for projectwide reports. In every Application Area there are three Work Areas, one each for Development, Quality Control, and Production.
Classification Hierarchies for Use in Browsing and Searching
In this example, there are two classification hierarchies used to create the user interface for displaying outputs in the Reports window: Project > Study > Site > Patient and Division > Department > Group.
In this example, each report output is classified to a single level of the Project > Study > Site > Patient hierarchy and to the Group level in the Division > Department > Group hierarchy. Therefore a link to each report is displayed twice in the Reports window, and users can browse for a report either by its group classification or by its project, study, site or even patient classification.
This classification hierarchy works well with the organizational structure shown in Example 1: Project Domain with Reporting on Separately Stored Study Data.
The Reports window display is based on the logical hierarchical structure of projects and their studies, sites and patients. The Project level contains all the company's project names as values, and the Study and Site levels contain all the company's study and site names, respectively, each linked to their project or study. The Patient level contains the Patient IDs of all patients participating in the project, each linked to their site. Most reports will apply to a whole project, study, or site, but from time to time there may be reports run on a single patient for medical reasons, and these reports are classified to the ID of the particular patient.
Subtype Hierarchy Level Assignments
All four levels of this hierarchy are assigned to every subtype of every object type, including organizational objects, object definitions, and object instances. None of the hierarchy levels is defined as Mandatory for any subtype. The default classification value for all is set to Inherited.
For Domains, a subtype called Top-Level Domain has all its classification levels set to Explicit. A subtype called Child Domains has all its classification levels set to Inherited.
This is the most flexible design and the simplest to set up.
Parent topic: Project > Study > Site > Patient
Assignments to Specific Objects
Individual objects are classified as follows:
- Project. The Project 123 and Project 456 Domains are each assigned to
the Project level with a value of Project 123 and Project 456 respectively. They do
not have values assigned for the Study or Site level. The Companywide Reports and
Company Standard Definitions Domains do not have any values assigned for any levels
in the Project > Study > Site hierarchy, and neither do any of the objects
they contain.
These Domains contain only definitions and definitions are not displayed in the Reports window, and they are not specific to any particular project, study, site, or patient so it is not necessary to classify this Domain to the Project > Study > Site > Patient hierarchy. These classifications would not be useful in either searching or browsing. However, Program, Report Set, and Workflow definitions within the Domain must be classified to a Group in the Division > Department > Group hierarchy; see Division > Department > Group.The project-level Application Areas are assigned to the Project level with a value of Inherited so that they are automatically classified to the same project as their Domain.
The Work Areas within the project-level Application Areas are also assigned to the Project level with a value of Inherited so that they are automatically classified to the same project as their Application Area.
All the object definitions in the project-level Application Area and in the Domain library, and all the object instances in their Work Areas, are also assigned to the Project level with a value of Inherited so that they are automatically classified to the same project as their container.
- Study. The study-level Application Areas are each assigned to the
Study level with the value corresponding to their study: Study 123ABC, Study 123DEF,
Study 456MNO, and Study 456PQR. The Project value they originally inherited has been
explicitly removed.
Each Work Area within each study-level Application Area is assigned to the Study level with a value of Inherited so that they are automatically classified to the same study as their Application Area.
Most object definitions contained in the study-level Application Areas and object instances contained in their Work Areas are also assigned to the Study level with a value of Inherited so that they are automatically classified to the same study as their Application Area.
- Site. Some object definitions and instances within a study-level Application Area or Work Areas generate or contain information that is specific to a site rather than to the whole study. Those particular objects are classified to the Site level, with the value of the particular site or sites whose data they contain, transform, or report. The study-level classification value they inherited has been explicitly removed.
- Patient. Some object definitions and instances within the study-level Application Areas or Work Areas generate or contain information that is specific to a particular patient; for example, a serious adverse event report. Those objects are classified to the Patient level. When the Definer creates Program to generate a report on information about a single patient, the Definer does not know in advance which patient will require the report. Therefore the Definer must make the Patient ID an input/output Parameter of the report. The Definer can also use this Parameter to classify the report to the appropriate Patient ID.
The company organization hierarchy allows people to browse for reports that pertain to their own group in the corporate structure. It has three levels: Division > Department > Group.
The Division level is the highest and includes as values the names of all corporate divisions that use Oracle LSH; for example, Development or Manufacturing. The Department level is the middle level and includes all departments that use Oracle LSH, related to their division. For example, the Development division value is linked to the Department values Biometrics, Clinical Science, and Project Management. The Group level is lowest and includes groups within the departments that use Oracle LSH; for example, the Biometrics department value is linked to Group values Data Management and Statistics, and the Clinical Science department is linked to Group values Clinical Pharmacology and Cardiology.
In this example, reports are always classified to the Group level. The Division and Department levels serve only to organize the groups into the correct structure to make the reports easier to find in the Reports window.
In this example, Oracle LSH is used only for clinical data, not financial or administrative or data originating in any division other than the Development Division. Therefore the Companywide Reports Domain and the Company Standard Definitions Domain are both classified to the Development division. The enrollment report is classified to the Data Management group and the investigators report is classified to the Project Management department.
Definitions and instances of Programs, Report Sets, and Workflows in all Domains are all assigned to the Division > Department > Group level. In all cases, the level is defined as Mandatory and the default value is blank, so that the Definer must enter a specific value for each object of those subtypes.
Planned Outputs and Execution Setups are also assigned to the Division > Department > Group as a mandatory level. The default value is Inherited. Planned Outputs automatically receive the classification value of their Program definition, and Execution Setups receive the classification value of their Program instance.
Parent topic: Division > Department > Group
Definers must enter a specific classification value in the Group level for each definition and instance of Programs, Report Sets, and Workflows when they create those objects. Unlike the Project > Study > Site classification hierarchy, where a particular Program might be used for different projects, studies, or sites, a Statistics Program will probably always be a Statistics Program, and a Cardiology Program will always be a Cardiology Program.
By default, outputs receive their Group classification from the Planned Output, which receives the classification value of the Program definition. Because a Statistics Program will probably always be a Statistics Program, and so on, this default behavior is almost always correct. However, it is possible for the Definer to override the default classification; See Classifying Outputs.
In this example, there are additional keyword hierarchies defined for use in searching for object definitions, instances, and outputs. Most are used only with objects of a particular type or subtype, as described in this section. Most are defined as Mandatory and have a blank default value, so that the Definer must select a classification value for each individual object. Keyword hierarchies do the following:
- Label Programs by Technology Type
- Label Load Sets by Type
- Label Data Marts by Format
- Label Programs by Purpose
- Label All Primary Objects with a Data Category
- Label Outputs and Data Marts for Submission to Regulatory Agencies
- Label Data Marts to be Sent to Research or Business Partners
Parent topic: Classification Example
A keyword hierarchy called Program Technology Types has classification values SAS, PLSQL, and Oracle Reports. Definers use the classifications to search for Program definitions to reuse.
Parent topic: Classification Hierarchies for Use in Searching Only
A keyword hierarchy called Load Set Type has classification values for all the different Load Set types, including SAS, Text, Oracle Tables and Views, and all the Oracle Clinical Load Set types (see "Defining Load Sets" in the Oracle Life Sciences Data Hub Application Developer's Guide). Definers use the classifications to search for Load Set definitions to reuse.
A keyword hierarchy called Data Mart Formats has classification values ASCII Fixed, ASCII Delimited, SAS CPort, SAS XPort, SAS Dataset, and Oracle Export. Definers use the classifications to search for Data Mart definitions to reuse.
A keyword hierarchy called Program Purpose has classification values that categorize the Program by its general purpose, such as: Combine Data and Report Data. You can include more specific values (such as Combine Demographic Data) or include different types of categories in the same list of values (such as Demography and Concommittant Meds) and assign multiple values to each Program, or use a separate hierarchy for labeling data (see below). Definers use the classifications to search for Program definitions to reuse.
A keyword hierarchy called Data Category has classification values that correspond to the data content of commonly used Tables; for example, Demography, Concommittant Medications, and Adverse Events. This hierarchy level is assigned to all definitions and instances of Programs, Workflows, Report Sets, Load Sets, Data Marts, and Tables. Tables are classified by the category of data they contain. Executable objects are classified by the type of data they operate on. Some objects are classified to multiple values.
A keyword hierarchy called Submission has values Not for Submission and For Submission. Report Sets, Data Marts, and their outputs that are intended for submission are labeled as such. This value, with the appropriate study or project value and other criteria, helps in assembling all the necessary data.
A keyword hierarchy called Partners contains the names of organizations with which the Oracle LSH customer needs to share data; for example, a pharma company creates a list of CROs, or a CRO creates a list of pharma companies. Data Marts and their outputs are labeled with the name of the organization they must be sent to.
Design Decision Summary
To create a classification system for use in searching and browsing, you must do the following:
Design a Set of Classification Hierarchies with Levels and Values
Design a set of classification hierarchies, including at least one with multiple levels, and define values in each level. If a hierarchy has multiple levels, they must be arranged in a strict linear hierarchy, and each value in the lower levels must be related to a value in the next higher level. See Defining Classification Hierarchies and Classification Example for further information.
Parent topic: Design Decision Summary
Restrictions
You must define at least one nonkeyword classification hierarchy for use in browsing, or nothing will be displayed in the Reports window of the Oracle LSH user interface.
Considerations
We recommend the following approach:
- Design one or more classification hierarchies to serve as the basis for the Reports window user interface. Design these hierarchies first, and in conjuction with the organizational structure (see Designing an Organizational Structure).
- Design as many additional hierarchies as you need to help users find object definitions and reports. For examples, see Classification Hierarchies for Use in Searching Only.
- If you plan to use Oracle LSH to process financial or administrative data as well as clinical data, define additional subtypes and hierarchies. You can add subtypes and hierarchies at any time.
If you want to be able to use values in a hierarchy level to label an object, you must assign the hierarchy level to the subtype of that object. For each hierarchy level assignment to an object subtype, you also define:
- Whether a classification to that hierarchy level is mandatory for objects of that subtype
- Whether Inherited classification is allowed for objects of that subtype
- A default classification for objects of that subtype (optional, and may be Inherited or, in the case of outputs, a classification parameter value)
Restrictions
If an output is not classified it does not appear in the Reports tab.
Parent topic: Assign Hierarchy Levels to Object Subtypes
Considerations
Take the following into consideration:
- For a child object to inherit a classification value, its parent must have the
same classification level assigned. If you define a classification level assigned to
an object subtype as Inherited, be sure to assign the same classification level to the
parent's object subtype. Otherwise Definers will receive an error if they try to use the
inherited classification.
For example, a Definer creates a Program definition using the Default subtype, which has the classification level Project > Study assigned and set to Inherited. If the parent Application Area does not also have the Project > Study level assigned, the Program definition cannot inherit a value from the parent Application Area. Therefore the system gives an error. The Definer must explicitly set the value for Study for the Program.
- The system tries to create new objects with the same subtype as their parent
object. When a Definer creates an object the system checks the subtype of the parent
object. If the new object has the a subtype with the exact same name, the system creates the
new object using that subtype by default. If not, the system uses the predefined Default
subtype.
For example, when a Definer creates a Program instance and definition at the same time, the system tries to give the instance the same subtype as the Work Area and the definition the same subtype as the Application Area. If Program instances do not have a subtype with the same name as the parent Work Area, the system uses the predefined Default subtype. If Program definitions do not have a subtype with the same name as the Application Area, the system uses the predefined Default subtype.
Therefore, if you define a Financial and a Clinical subtype for all object types, and define one top-level Domain as Financial and another as Clinical, by default the system creates all objects in the Financial Domain as Financial and in the Clinical Domain as Clinical.
The Definer can change the subtype as necessary.
- Coordinate your classification level assignments for Execution Setup subtypes
and for Output subtypes. Subtypes defined for Outputs are used by Planned Outputs.
If you want an Output to inherit its classification values from its Execution Setup, which belongs to the executable instance in a Work Area, rather than its Planned Output, which belongs to the executable definition in an Application Area or Domain, set the Planned Output's classifications to Inherited. However, if the Execution Setup does not have the same classification levels assigned as the Planned Output, the actual output will inherit values for the missing levels from the Planned Output's parent; namely, the executable object definition.
- For maximum flexibility, make all classification levels optional and inherited for all objects except organizational objects—Domains, Application Areas, and Work Areas—so that all primary definitional objects inherit their classifications from the Domain, Application Area, or Work Area where they are located. Do not define default classifications.
- Mandatory Classifications. If you define a level as mandatory for Output subtypes and the Definer does not provide a default value, Oracle LSH will not execute the job to generate the output unless the person who submits the job provides a value.
- Multiple Displays. If you assign multiple hierarchy levels to an Output subtype and an actual output is classified to them, it appears in multiple locations in the Reports screen.
Assign Hierarchy Levels to Domains, Application Areas, and Work Areas
As you set up your Domains, Application Areas, and Work Areas, assign classification values to them according to your design. If you are using Inherited for any object subtypes, objects of those subtypes will automatically be assigned the same values as they are created. You may need to remove some of these inherited classifications. See Allowing Classification by Inheritance and Classification Example.
