Call the Create Technology Type API
To create an Technology Type, call the public API CDR_PUB_ATK_ADAPTER.POPULATETECHTYPES.
Its signature is:
PROCEDURE populateTechTypes ( p_api_version IN NUMBER ,p_init_msg_list IN VARCHAR2 default CDR_PUB_DEF_CONSTANTS.G_FALSE ,p_commit IN VARCHAR2 default CDR_PUB_DEF_CONSTANTS.G_FALSE ,p_validation_level IN NUMBER default CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL ,x_return_status OUT NOCOPY VARCHAR2 ,x_msg_count OUT NOCOPY NUMBER ,x_msg_data OUT NOCOPY VARCHAR2 , pio_techTypeRow IN OUT NOCOPY cdr_tech_types%rowtype );
param pio_techTypeRow is a mandatory parameter of row type cdr_tech_types table that contains object attributes. Enter values as follows:
- tech_type_id. Contact Oracle Support to get a 12-digit ID for your technology type that is unique across all adapters developed for use with Oracle Life Sciences Data Hub.
Make a note of the number you enter; you will need it when you create an Adapter Area. - tech_name_rc. Enter a name for the new technology type you are creating. You must add the name to the CDR_TECH_TYPES lookup (see Adding Lookup Values).
- tech version. Enter the correct version of the external system.
- service_type_rc. The service type required for this technology type. You must add this service type value to the CDR_SERVICE_TYPES lookup (see Adding Lookup Values).
- build_ide_cfg_function. (Visualization and Program adapters only.) Enter the name of your Pre-installation function, if any; see Build_IDE_Cfg_Function.
For this function name and the others below, do not include the schema name. Enter onlypackage_name.procedure_or_function_name - owb_operator. Enter the Oracle LSH operator that it should
use for this adapter:
- If the external system is located on the database, enter:
CdrPLSQLImmediate_1These adapters use PL/SQL to execute their defined objects. - If the external system is located on an operating system,
enter:
CdrSERVICE_1. These adapters use the Distributed Processing (DP) Server to execute their defined objects; see the chapter on setting up services in the Oracle LSH System Administrator's Guide for more information. - If your adapter is for an IDE, enter:
CdrService
- program_type_rc. Enter the type of defined object created using this adapter:
$PROGRAMTYPES$LOADSET,$PROGRAMTYPES$DATA_MART,$PROGRAMTYPES$PROGRAMor$PROGRAMTYPES$BUSAREA. - pre_install_function. Enter the name of your Pre-installation function, if any; see Pre_Install_Function.
- install_function. Enter the name of your Installation function, if any; see Install_Function.
- post_install_function. Enter the name of your Postinstallation function, if any; see Post_Install_Function.
- pre_execution_function. Enter the name of your Pre-execution function, if any; see Pre_Execution_Function.
- execution_function. Enter the name of your Execution function, if any; see Execution_Function.
- post_execution_function. Enter the name of your Postexecution function, if any; see Post_Execution_Function.
If any of these functions returns an error the job returns an error. If any of these programs returns a warning then the job returns a warning unless another part of the job generated an error.
Parent topic: Creating a Technology Type
