Planning Programs and Packages
Each custom function and procedure required for your adapter must be contained in a PL/SQL package (Package B) and the package must be uploaded to a Source Code definition in the Program definition in your Adapter Area.
The required functions and procedures can all be in the same package or in different packages. If multiple people are developing the adapter, it may be helpful for each of them to work on a separate package, upload each package to a different Source Code definition and create a different Program for each Source Code definition so that each Program can be installed separately. However, all Program instances must be contained in the same Work Area.
It is very important to have only one Work Area in an Adapter Area. This ensures that all the custom PL/SQL packages you write are installed in the same schema.
Parent topic: Developing an Adapter
