3 Developing an Adapter
Developing an adapter requires you to understand the overall process. You should plan your programs and packages carefully.
For details on this process, see the following:
- Adapter Development Process
The adapter development process is detailed. You should understand this process before beginning your development. - Planning Programs and Packages
Each custom function and procedure required for your adapter must be contained in a PL/SQL package (Package B) and the package must be uploaded to a Source Code definition in the Program definition in your Adapter Area. - Using the Security API Package During Development
You must call a security API, CDR_PUB_API_INITIALIZATION, from every package that calls an Oracle Life Sciences Data Hub API and that you intend to run from outside Oracle LSH.
