Roles and Privileges Required for Exporting
When you execute the script you must supply an Oracle Life Sciences Data Hub user account that has the following privileges:
- Modify privileges on all objects types that have to be exported
- The LSH Checkin Admin application role, if there are objects in the Domain that are checked out by a user other than this Oracle LSH application user
These privileges are required because the export script has to check in all checked out objects before proceeding with the rest of the export process.
If the application user does not have sufficient privileges, and the export script needs to check objects in, the export fails.
See Setting Up the Security System for more information on granting roles and privileges in Oracle LSH.
Parent topic: Exporting Objects
