Exporting Objects
If you have the required role and privileges, you can fully or partially export objects.
The export script:
- Checks in all the objects being exported, with the checkin comment "Checked in by IEU."
- Creates a zipped file with the name of the Domain as filename
domain_name.zip). This file contains the metadata for exportable objects contained in the Domain. - Places the log file (domain_name.log) separately in the same directory; see Export Log File Content.
- Full and Partial Export
When you run the export script, you must enter a parameter value to indicate whether you want to perform a full or partial export. - Roles and Privileges Required for Exporting
When you execute the script you must supply an Oracle Life Sciences Data Hub user account that has the following privileges: - Creating the Directory and Running the Export Script
To run the export process, do the following from the database server where you have the Oracle Life Sciences Data Hub source database instance installed: - Export Log File Content
The script does not run at all if you provide incorrect usernames (database and/or application user) or an incorrect database directory name. Rerun the script with correct parameter values in that case.
Parent topic: Exporting and Importing Objects
