Full and Partial Export
When you run the export script, you must enter a parameter value to indicate whether you want to perform a full or partial export.
- Full export. The export script automatically includes the Domain you specify and almost all the objects it contains (see Objects Included and Objects Excluded).
- Partial export. You must populate a database driver table with a list of the objects to be included. The script automatically includes objects contained in the objects you specify, including objects contained in those objects and objects required for those objects to exist, as described in Populating the Driver Table and within the limits described in Objects Included and Objects Excluded.
This section contains the following topic:
- Populating the Driver Table
The driver table must include a single column that contains the object ID of objects you want to include in the export.
Parent topic: Exporting Objects
