Setting "Hard to Guess" Requirement
This profile enforces requirements that make it more difficult to guess what another user's password might be.
These requirements come as a package; you must either accept or reject the whole. Oracle recommends a setting of Yes (to accept the package) for use with Oracle Life Sciences Data Hub.
To set the "Hard to Guess" requirement, do the following:
- Log in. See How to Log In to Oracle Applications Profile Forms.
- In the Profile field, enter
Signon Password Hard To Guess - Click Find.
- Click in the Site column. An ellipsis (...) appears on the right-hand side of the field.
- Click the ellipsis (...). A pop-up box appears.
- Click Yes and then OK.
- In the File menu, select Save and Proceed. The system displays a message that the transaction is complete.
- Click OK. The transaction message pop-up disappears.
- Click the X in the upper right corner of the System Profile Values window to close the window.
Parent topic: Setting Password Requirements
