Setting Password Length Requirement
This profile determines the minimum number of characters required in a user's Oracle Life Sciences Data Hub login password.
The default setting is 5. Oracle recommends a setting of 8 or more for use with Oracle LSH.
To set the password length requirement, do the following:
- Log in. See How to Log In to Oracle Applications Profile Forms.
- In the Profile field, enter
Signon Password Length - Click Find.
- In the Site column, replace the default value, 5, with
8(or a higher number, if you choose). - In the File menu, select Save and Proceed. The system displays a message that the transaction is complete.
- Click OK. The transaction message pop-up disappears.
- Click the X in the upper right corner of the System Profile Values window to close the window.
Parent topic: Setting Password Requirements
