Setting Password Requirements
A password expiration utility is available if the System Administrator requires that all users convert to case sensitive passwords upon the next login.
This utility expires all passwords in FND_USER, including that of SYSADMIN and default Vision accounts, and can be run as a SQL Script ($FND_TOP/sql/AFCPEXPIRE.sql) or as a Concurrent Program (FNDCPEXPIRE_SQLPLUS).
For more information see the Oracle E-Business Suite System Administrator's Guide - Maintenance at http://docs.oracle.com/cd/E18727_01/doc.121/e12894/T202991T202995.htm.
Oracle recommends that you use the profile settings described in this section to provide optimal security in login password usage, including:
- Setting Password Length Requirement
This profile determines the minimum number of characters required in a user's Oracle Life Sciences Data Hub login password. - Setting "Hard to Guess" Requirement
This profile enforces requirements that make it more difficult to guess what another user's password might be. - Enabling "Forgot Your Password?" Functionality
For Oracle Life Sciences Data Hub, Oracle recommends a setting of 40 for the Local Login Mask profile. - Setting a Limit on Log-In Attempts
This profile option determines the maximum number of logins a user can attempt before the user's account is disabled. - Setting a Time Limit on Password Reuse after Resetting Password
This profile will set the minimum number of days that a user must wait after changing his or her password before being allowed to reuse a password.
Parent topic: Setting Profile Values
