Modifying Hierarchy Levels
You can modify level attributes as follows:
Name. You can modify the level name. The system automatically updates the level name everywhere it appears in the user interface, including the classification screen for all objects classified to the level or a level below it in the same hierarchy.
- Description. You can modify the description.
- Entry Length. You can modify the Entry length.
- Term Uniqueness. You cannot modify the Term Uniqueness attribute.
- Allow Classification. You cannot modify the Allow Classification attribute.
Parent topic: Modifying Hierarchies and Terms
