Modifying Terms
To modify a term:
  1. Go to the Terms subtab in the Classifications tab.
  2. Navigate to the hierarchy that contains the term you want to modify.
  3. Click the pencil icon in the Maintain Terms column of the parent of the term you want to update.
  4. You can modify term attributes as follows:
    1. You can change a term's Approved setting from No to Yes at any time.
    1. You can change the Approved setting from Yes to No only if the term has not been used either as a default classification for an object subtype or to classify an object and no approved child terms are associated with the approved term.
You can remove a term only if it has not been used in any way and does not have any child values.
