Define Values
This section displays the following settings:
List of Values: If you have provided a method to determine the Parameter's value, a list of values that are valid for the Parameter appear here. Else the value for this field is None.
Default Value: If you have specified a default value for the Parameter, the value appears here.
See Defining Allowed Values for more details on defining values for Parameters.
Parent topic: Using the Parameter Properties Screen
