Developing Standard Definitions and Modular Applications
You can reduce the amount of time required to develop and validate applications by creating standard object definitions and reusing them as much as possible.
To encourage Definers to reuse standard definitions, make it clear which definitions are standard by storing them in a library created especially for that purpose and/or classifying them as Standard, for example.
Following are a few strategies for developing fstandard object definitions:
- Develop standard Table definitions. If you have a standard set of Tables, with standard data types and lengths for corresponding Columns in different Tables, then you can easily reuse the same Table definition at different points in the data flow, and write standard Programs to read from and write to the standard Tables.
You can develop your own company standards or use external standards such as the CDISC data model.
The standard data model you use must be compatible with the data model of the source system(s) you use. For example, if the Patient ID column or variable has a length of 8 in the source system, the Patient ID Column in a standard Oracle Life Sciences Data Hub Table must have a length of 8 or more.
- Define more Programs with a smaller scope instead of fewer Programs with a larger scope. You can then use the smaller-scope Programs as modules in multiple applications.
For example, rather than define a single Program to merge data from different studies and then analyze the data, define two separate Programs, one to merge data and the other to analyze data. Both Programs are reusable in more situations. You can reuse the combining Program before different analytical Programs, and you can reuse the analytical Program, with minor modifications, on data from either a single study or multiple studies.
You can include a series of Programs in a single Workflow, so that you can run all the Programs in a single process, so that there is no time lost by running separate Programs; the successful execution of one Program triggers the next in the series, and some Programs can run in parallel.
- Use Parameters. Make executable object definitions more reusable by defining Parameters to contain information that may clearly change from one use of the definition to another.
For example, if you want to use the same Program to generate a Demography Report in several different studies, create a Parameter to contain the study name. You can either make the Study Parameter enterable by the user who runs the report, or, in the Execution Setup for each instance, bind the Study Parameter to the value appropriate for each study.
- Create Parameter Sets based on standard Table definitions. Both Oracle LSH Parameter and Column definitions are based on a data structure called an Oracle LSH Variable, which determines their data type and length. You can create Parameter Sets containing Parameters based on the same Variables on which a Table's Columns are based, and give the Parameter Set the same name as the Table so that, when you are defining Program Parameters, you can easily find Parameters with the same data type and length as the corresponding Table Column. This approach has two advantages:
- It promotes data type and length consistency along the data flow.
- It makes automatic Parameter value propagation in Workflows and Report Sets easier to set up.
Parent topic: Getting Started
