Modifying Load Set Definition Properties
You can go to a Load Set definition's Properties screen in one of the following ways:
From the Load Set's Properties screen: Click the hyperlink of the Load Set definition that appears in the Definition field.
From the Domain or Application Area where you created the definition: Click Manage Definitions to view all the definitions in that Domain or Application Area. Click the definition name.
Once on the Load Set definition screen, click Update to enter changes. Oracle LSH creates a new version of the definition. You can change the following properties:
Name: See Naming Objects for further information.
Description: See Creating and Using Object Descriptions for further information.
You can modify some properties through the Actions drop-down list; see Using the Actions Drop-Down List for further information.
