Modifying Attributes and Parameters
You cannot add or remove Attributes or Parameters because they are predefined for each Load Set type.
You can change some Parameter values in one or more Execution Setups. Select Execution Setups from the Actions drop-down list in the Load Set instance in the Work Area. See Creating, Modifying, and Submitting Execution Setups.
Parent topic: Modifying Load Set Definition Properties
