Parameters and Execution Setups
When you generate a default Execution Setup for a Program, the system automatically includes a copy of all the Parameters you have defined.
You can modify Parameter settings in the Execution Setup to control the options available to the person submitting the Program for execution; for example, if a Parameter is set to Read-Only in the Execution Setup, a user submitting the Program for execution cannot change the value of that Parameter. Execution Setups contain a copy of the Parameters and changes made to Parameters in Execution Setups do not affect Parameter settings in a Program definition or a Parameter definition.
You can define multiple Execution Setups, each with different Parameter settings; see Creating, Modifying, and Submitting Execution Setups.
Parent topic: About Parameters
