Using the Search and Select Window
The Search and Select window is called from many screens in Oracle Life Sciences Data Hub. It receives its context from the calling screen. For example, if you click the Search icon in the Create Program screen, the Search and Select function finds only Program definitions.
Enter values in the following fields:
Parent topic: Creating an Instance of an Existing Definition
