Using the Work Area Properties Screen
To reach the Work Area Properties screen, click the Applications tab and navigate to the Application Area that contains the Work Area, then click the Work Area's hyperlink. You can also use the Search field from many other Oracle LSH screens.
You can see information about the Work Area as a whole and about all the object instances it contains.
Oracle Life Sciences Data Hub (Oracle LSH) Work Areas are designed to allow many people to work simultaneously on developing different parts of a single application. In addition, depending on your company's policies, you may have one or more Work Areas of your own to work in. You may or may not be able to create Work Areas yourself.
As you define the objects required for a particular application, you must install them in the database before you can run the executable objects or write data to tables; see Installing a Work Area and Its Objects.
- Work Area Properties
- Viewing a Work Area's Installation History
- Viewing a Work Area's Version History
- Changing a Work Area's Usage Intent
- Object Instance Information
- Object Instance Actions
- Adding Object Instances to a Work Area
- Managing Table Instance Snapshot Labels in a Work Area
Parent topic: Using, Installing, and Cloning Work Areas
