Application Areas
Application Areas contain exactly the same objects as Domains, except that Domains contain Application Areas and Application Areas contain Work Areas. Both Domains and Application Areas can include all object definition types. Figure B-2 shows all possible layers of object ownership within an Application Area.
Report Set Entries inside Report Set Definitions can be nested indefinitely.Figure B-2 Object Ownership within an Application Area
Description of "Figure B-2 Object Ownership within an Application Area"
Parent topic: Object Ownership
