Work Areas
Work Areas contain object instances, each of which points to an object definition located either in an Application Area or in a Library. This diagram shows only object ownership, so you cannot see the pointers to the definitions. Most object instances point to an object definition with the same type name; for example, Program instances point to Program definitions. There are two exceptions: both a Parameter and a Table Column point to a Variable as their definition source. Figure B-3 shows all possible layers of object ownership within an Application Area.
Figure B-3 Object Ownership within a Work Area
Description of "Figure B-3 Object Ownership within a Work Area"
Parent topic: Object Ownership
