Audit Trail
Oracle LSH can store data in a manner that is compliant with industry regulations: with an audit trail of every change to every record.
Whether or not Oracle LSH maintains an audit trail on the records in a particular Table instance depends on the Data Processing type you define for the Table instance. In most cases when a record is deleted it remains in the database associated with an end timestamp and an additional row explicitly recording the deletion. It is therefore possible to reconstruct the data in a given Table instance as it was at any point in time.
Parent topic: Storing Data
