Work Areas
All data storage, manipulation and viewing in Oracle LSH must be performed in Work Areas. In a Work Area you create instances of Load Sets, Programs, Tables, and any other definitional objects that are required to accomplish a particular business purpose, and install the Work Area in the database.
When you install a Work Area for the first time, Oracle LSH creates a database schema and creates a database object from each object instance in the Work Area. Oracle LSH stores the data you load or write to Table instances in the Work Area in the corresponding database tables in the schema.
You can use Work Areas to create your development, quality control, and production environments. When you are ready for formal testing of the Programs and other objects you have created in the development Work Area, you can clone the development Work Area to create the quality control Work Area and install the same objects to a new schema, load fresh data, and run tests. Then clone the quality control Work Area, install it and load production data to create your production Oracle LSH environment. Oracle LSH supports this usage by enforcing a number of rules; see Work Area Usage Intent and Validation Status for further information.
Parent topic: Storing Data
