Storing Data
Oracle LSH allows you to store data from a variety of external systems in a single repository.
Oracle LSH allows you to blind data and to break the blind or permanently unblind the data with a combination of security privileges. Blinded data you load from Oracle Clinical is automatically blinded in Oracle LSH. For other source data systems, the first time you load data that should be blinded you must specify that the target Oracle LSH table be blinded. See Security for Blinded Data for further information.
