Data Manipulation
To combine, analyze, and report on the data you load into Oracle LSH, you write programs. These programs can be developed in SAS, Oracle PL/SQL, or Oracle Reports.
Each of these development environments is closely integrated with Oracle LSH. Oracle LSH stores the program code under version control. When you run a program in Oracle LSH, the system sends the job to the appropriate engine for execution. If the program writes data to tables, Oracle LSH tables receive the data. If the program generates a report, you can view the report, as well as the program's log file, through Oracle LSH.
If you are currently using SAS to analyze clinical data, you can upload your programs, macros, and formats and continue using them in Oracle LSH. If you have SAS installed on your personal computer, you can open SAS directly from Oracle LSH and view Oracle LSH source data.
You can combine a series of programs into a single executable process; for example, automatically load fresh data into Oracle LSH at regular intervals, generate a report on the new data after each load, and send an email notification that the report is ready to the appropriate personnel.
Parent topic: About the Oracle Life Sciences Data Hub
