About the Oracle Life Sciences Data Hub
The Oracle Life Sciences Data Hub (Oracle LSH) is a powerful and flexible data integration and statistical analysis tool. It is closely integrated with several external tools, notably the Oracle Business Intelligence Suite and SAS and can also be integrated with other tools using the Oracle LSH Adapter Toolkit. Oracle LSH allows you to load and analyze data from diverse systems, including clinical data management and remote data capture systems.
Oracle LSH is designed to help you comply with pharmaceutical industry regulations: it maintains an audit trail of data transactions, stores all programs and tables as database objects under version control, and provides tools for validating these objects and, by extension, the data they touch within Oracle LSH. Using labeled or timestamp-based data snapshots and program versions, you can recreate submitted data.
However, the Oracle Life Sciences Data Hub is not restricted to use with clinical data; you can use it to store and analyze financial, administrative, or any other kind of data as well.
Oracle LSH's functionality covers three basic areas:
Parent topic: Overview
