Definitional Object: Load Set
The Oracle LSH definitional object used in loading data is called a Load Set. In addition to loading data, the Load Set reproduces the meta-data of the external Oracle table or SAS data set in Oracle LSH.
Once defined, Load Sets are saved and each subsequent time they are run they update the data in Oracle LSH to reflect changes in the source data. You can schedule a Load Set to run at regular intervals to refresh data.
If the external system is an Oracle database you can define the Load Set as a view against the source table or data set. This means that without actually loading the data into Oracle LSH you can browse the data dynamically in the external system as if it were a database view.
Parent topic: Loading Data
