Setting a Default Classification
When you assign a classification hierarchy level to an object subtype, you can set one or more default classification values for objects of that subtype. Whatever value you set as the default classification is applied to every object created of this subtype. You can override the default classification for an object at any time.
Default classifications for subtypes are not required. You can set two types of default classifications:
- Default classification by inheritance
- Default classification to a specific value
