Setting the Default to a Specific Value
You can enter one or more specific values for each hierarchy level assigned to a subtype. Every object created as that subtype then is automatically classified the same way.
For example, if the classification level Project > Study is assigned to the subtype, you could set values such as Project01 > Study01 and Project01 > Study02.
This approach is not recommended because the point of classifying objects is to differentiate them in an appropriate way.
Parent topic: Setting a Default Classification
