Study 123ABC Production User Group
The Study 123ABC Productionuser group is assigned to the Study 123ABC Production Work Area. The Production Work Area controls security access to the Oracle LSH schema that contains production data and outputs on production data. Therefore all personnel who need to see reports on production data need access to the Production Work Area.
This is the first user group in this example to differentiate between privileges on one subtype and another. In this security system, Programmers, Data Managers, and Quality Control Engineers can work on objects of any subtype; for example, Financial or Clinical Report Sets. However, the Production Work Area user group includes users who can see only Clinical object subtypes, users who can see only Financial object subtypes, and some users who can see both subtypes.
In this example, the Study 123ABC Development user group is explicitly unassigned from the Production Work Area so that Programmers cannot change object instances in the production environment.Some of the roles listed here have the same privileges on the same object types. From the point of view of Oracle LSH, a single role could be substituted for these. However, it may be easier to administer user accounts if you create roles for actual job titles in use in your company and assign them to the people who hold those jobs.
The following roles have Submit and View privileges on instances of Programs, Report Sets, Workflows, and Business Areas (for data visualizations). They also have the Read Data operation on Table instances so they can run executables on Table instances, and the View operation on outputs.
Most roles should include
- Investigator. Has operations on subtype Clinical Programs, Report Sets, Workflows, and Business Areas only.
- Statistician. Has operations on subtype Clinical Programs, Report Sets, Workflows, and Business Areas only.
- Project Manager. Has operations on both subtypes: Clinical and Financial Programs, Report Sets, Workflows, and Business Areas.
- Blind Break Manager. Has operations on subtype Clinical Programs, Report Sets, Workflows, and Business Areas only.
The following roles have Submit and View privileges on Execution Setups of Load Sets and Data Marts in addition to Programs, Report Sets, Workflows, and Business Areas:
- Trial Manager. Has operations on both subtypes, Clinical and Financial, for each object type.
- Submission Officer. Has operations on only the Clinical subtype of each object type.
Three additional roles allow certain operations on blinded data. By creating a separate role for this purpose, you can limit this sensitive privilege to the minimum number of people required to perform it in your organization. You can assign these roles to users who also have other roles. See Security for Blinded Data.
These roles are different from the LSH Data Blink Break User application role and the LSH Data Unblind User application role. One of those application roles is required in addition to these object-specific roles to create a blind break or unblind data. See Table 4-1.In addition, the user must be assigned to one of these roles in a user group with access to the object.
- Blind Break. The Blind Break role includes the Blind Break operation on Table instances and on outputs. The Blind Break role allows a user to run a Program or other executable on a Table instance with a Blinding Status of Blinded and view the resulting outputs (see Security for Blinded Data).
- Permanently Unblind. The Permanently Unblind role includes the Unblind operation on both Table instances and outputs. The Unblind operation allows the user to change the Blinding Status of the Table instance or output from Blinded to Unblinded.
- View Unblinded Data. The View Unblinded Data role includes the Read Unblind operation on both Table instances and outputs. Even after a Table or output has been permanently unblinded, this role is required to see the unblinded data.
Parent topic: Example User Groups
