Allocating Tasks to Workers
You can allocate tasks to workers in several different ways:
- Using Direct Allocation
- Using Automatic Pool Allocation
- Using Manual Allocation by Term
- Tracking Users' Workloads
Parent topic: Allocating Tasks to TMS Users
To use direct allocation, follow the instructions in Setting Up Task Allocation. Direct allocation then proceeds automatically, allocating tasks as soon as an omission, unapproved VTA, or unapproved Action assignment is created in any way.
Check the Maintain Direct Allocation Log Files window periodically to see if direct allocation has completed with errors. Each time direct allocation fails, the system enters the information in this window.
For each failed job, the system displays an error log ID, the user ID of the person who ran the job that created the omission(s), VTA(s), or Action(s), and the timestamp of that job. The system displays a detail ID for the error and an error message in the lower portion of the window for the error log selected in the upper portion of the window. The thi_term_id may appear in the error message.
You can use a SQL*Plus tool to determine the name of the term, domain, and base dictionary from their respective IDs and then correct each problem manually.
Parent topic: Allocating Tasks to Workers
In the Task Allocation by Quantity window you can invoke an algorithm to automatically allocate tasks. You have more control over the process than with Direct Allocation, but you must explicitly invoke the algorithm. You can allocate only one type of task at a time: omissions, unapproved VTAs, or unapproved Action assignments. You can allocate tasks in only one domain/dictionary combination at a time.
You can specify the workers to whom you want to allocate tasks and set workers' capacities each time you run the job. You can choose either an algorithm that allocates tasks based on workers' current workload as well as their capacities, or use an algorithm that uses only their relative capacities.
Reallocating and Unallocating Tasks
You can use the same method to reallocate tasks from one worker to one or more different workers and to unallocate tasks—that is, remove task assignments from a worker and put the tasks back into the Unallocated pool.
Unlike direct allocation, automatic pool allocation allows assigning an approval task to the same user who created the VTA or Action assignment requiring approval, if the user has the required privileges.
To use automatic pool allocation, reallocation, or unallocation, do the following:
Use the Task Allocation by Term window to manually allocate, deallocate, or reallocate a single omission, unapproved VTA, or unapproved Action assignment to a particular user.
You can manually allocate multiple omissions, unapproved VTAs, or unapproved Action assignments to a single user in the Task Allocation by Quantity window; see Using Automatic Pool Allocation.
Unlike direct allocation, manual allocation allows assigning an approval task to the same user who created the VTA or Action assignment requiring approval, if the user has the required privileges.
To allocate, deallocate, or reallocate a single omission, unapproved VTA, or unapproved Action assignment, do the following:
You can see the current workload for any user in the Task Allocation by Quantity window and by creating a list of activities for any user. In either case, you can only view one task type—omissions, unapproved VTAs, or unapproved Action assignments—at a time.
For more information, see:
Tracking Workloads in the Task Allocation by Quantity Window
To see a user's current number of tasks, do the following:
Parent topic: Tracking Users' Workloads
Tracking Workloads as Activities
You can use the filter pop-up window to create a list of omissions, unapproved VTAs, or unapproved Action assignments for a single user or for all users, for any dictionary/domain combination or for all dictionaries and all domains. If you save the filter as an activity, you can then view it at any time from the Activity List window in the Omission Management menu.
The Activity List window always displays a summary of the current results of the query you defined in the filter window, including the task type, dictionary, domain, term status, and current total.
You can double-click the activity name to see the individual tasks retrieved by the query.
You specify filter criteria in the Filter pop-up from the appropriate window, as follows:
To retrieve allocated omissions, go to the Classify VT Omissions window.
To retrieve allocated unapproved Action assignments, go to the Approve Action Assignments window.
To retrieve unapproved VTAs, go to the approve VTAs window.
For instructions, see Creating and Using Activity Lists.
