Creating and Using Activity Lists
This section includes:
Parent topic: Omission Management
You can use the Activity List window in the Omission Management menu as your starting point for work every day. You can set up your activity list to organize the tasks allocated to you (if your company is using task allocation) and keep track of the tasks you have not yet done. Each activity lists a single type of task—omissions to be classified, unapproved VTAs or Action assignments to be approved—in a particular domain/dictionary combination or in all domains and/or all dictionaries.
You can click the activity name to see and work on the individual tasks allocated to you in the appropriate window: Classify Omissions, Approve VTAs, or Approve Action Assignments. When you close the window you return to the Activity List window and you can proceed to a different activity.
To create an activity, enter criteria in the filter pop-up window in the Classify Omissions, Approve VTAs, or Approve Action Assignments and save the filter as an activity (see Setting Filters and Creating Activity Lists).
The Activity List window always displays a summary of the current results of the filter, including the task type, dictionary, domain, term status, and current total.
You can also create activity lists of other users' tasks, though you will only be able to see terms to which you have standard Data Access Group security access.
Parent topic: Creating and Using Activity Lists
In the Classify VT Omissions, Approve Action Assignments, and Approve VTAs windows you can limit the results returned by queries in the window by setting Filter criteria. You can save the filter criteria settings as an activity list and access it through the Activity List window. See:
Setting Filters
The values you set here limit the results retrieved by queries in the window. For example, if you specify a dictionary, TMS displays only terms in that dictionary.
Your default filter criteria settings are determined by your TMS user profile. Any changes you make to the filter settings continue in effect throughout your current session, even if you change windows, until you change the setting again. If your user profile does not set defaults, and you have not selected any during your TMS session, the Filter window opens automatically when you launch any of these windows.
To set filter criteria, do the following:
Parent topic: Setting Filters and Creating Activity Lists
Saving Filter Settings as an Activity
You can save filter settings as an activity list to organize your work in TMS. See Creating and Using Activity Lists for information.
To save filter settings as an activity list accessible from the Activity Lists window, do the following:
Maintaining Activity Lists
Use the Maintain Activities window to clean out outdated filters that are taking up space in your Activity List. You can also rename activities here.
If you have the OPA_ADMIN database role you can see all activities, regardless of who created them. Otherwise you see only the activities that you created.
To delete an activity:
- In the Omission Management menu, go to the Maintain Activities window.
- Query for the activity you want to delete. See Querying in Windows. You can query on the type, whether or not the list is available to all users, and/or the activity text.
- Select the activity you want to delete by clicking its name.
- In the Record menu, select Delete.
- Save.
