Cruise Property Management Border Control Database Updater
The CruiseBorderControlDBUpdater_23.1.0.0.exe installshield creates a folder that distributes the necessary DLLs and the OHC BC Database Updater, which allow you to update the database required by Border Control.
The installation requires the user performing the installation to have Administrator privilege.
Pre-requisites
Microsoft .NET Framework 2.0, 3.5, and 4.8 features are enabled on the target machine.
Oracle 19c Database client with ODAC is installed on the target machine. See topic Oracle Database Client and ODAC Installation in the SPMS Installation Guide.
Installing Cruise Property Management Border Control Database Updater 23.1x
Log in as a Microsoft Windows Administrative user.
Start the installation program by right-clicking the CruiseBorderControlDBUpdater_23.1.0.0.exe and select Run as Administrator.
Click Next and navigate to the “Custom Setup” window. The default installation folder is
C:\Oracle Hospitality Cruise\
If you choose to install it to a different folder, you need to grant the folder full permission so that the user can start the Database Updater.
Click Next and navigate to the “Ready to Install” window.
Click Install to begin installation.
Uninstalling Cruise Property Management Border Control Database Updater 23.1x
Start the installation program by right-clicking the CruiseBorderControlDBUpdater_23.1.0.0.exe and select Run as Administrator. If 23.1 is already installed, the Setup starts in Maintenance mode, allowing you to remove or reinstall.
Select the available option and wait until uninstall is complete. In the case of reinstall, follow the prompts presented to uninstall and install.
OHC Border Control Database Updater
The OHC Border Control Database Updater is a program that update the database required by Border Control.
Run the Windows Explorer program and navigate to the
\Oracle Hospitality Cruise\Border Control DB Updater\v23.1
Double-click the OHC Border Control Database Updater.exe to launch the program.
At the Welcome screen, click the Next button to navigate to the next screen.
On the Database Connection screen, enter the SPMS Database TNS name and Database Schema Password.
If the Database TNS name or Database Schema password is incorrect, you will receive an error message. Correct the information and retry.
- To validate the Database connection, click the Test Connection button.
Click the Next button to proceed to the Options screen and select the mode to run.
Standard: Updates the Database with the required changes.
Simulation: Checks and generate a list of changes that would be applied however no changes will be applied on the database.
Click the Next button to confirm and proceed with the install.
Click Next to start the process.
The progress of the update is shown in the Status screen. When the update process completes, click the Next button to proceed.
Once the database update completes, you will find a process log is saved in the Public Document folder
“C:\Users\Public\Document\Oracle Hospitality Cruise
”. Alternatively, you can click the Copy to Clipboard button to save the file. -
Click the Finish button to exit the Database Installer.
