10 Management Module
Like Advance Quick Check In, a new field is also added in Management module, Cashier, Guest Handling (from SPMS v20.3 and above). This field is located at the Guest Info tab, and under the Passport Information/Custom Info section and is a view only mode, showing the response status received from EES.
This field is also available in Expected, Check-In, Check-Out, Cancelled and No-Show tabs.
You can also add the EES Status field in Guest Info.html for the status to display.
