9 Advance Quick Check In Module
A new field EES Status is added to Advance Quick Check In (from SPMS v20.3 and above) and you will find it in Passport Details section. You can customize to have the field appear in different tabs using the drag and drop action and this would require the parameter Quick Check in, Customize QCI enabled.
Figure 9-1 Advance Quick Check In
