8 WPF Security Module
You will need to configure the same alert in WPF Security module for the guest movement from ship to ashore. This is only applicable to Guest type.
You are required to define the Arrival Harbor Country in Administration module, System Cruise Setup.
Once set up, an alert will be triggered when the guest’s EES response status is either NOK EES or NOKETIAS, and the Arrival Harbor Country matches the country defined in the security alert.
