6 Installation of Fleet Management Component or Add-On
The following topic describes the installation steps of Fleet Management Component or Add-On
  1. Download the Installation file from Oracle Software Deliver Cloud (OSDC)/ MOS.
  2. Extract the zip file using the Extract Here.
    Figure 6-1 Downloaded Installation File (Zip format)
    This figure shows the downloaded installation file in zip format
  3. Open the Setup folder from the above extracted zip file.
  4. Right-click the OHCFM.exe and select Run as administrator to install the application.
  5. On the Fleet Management Suite Installation Welcome screen, click Next to continue.
  6. Select the required Components or Add-Ons, and then click Install to install Fleet Management or click Cancel to cancel the installation process.
Post Installation Notes
  • See Secure Clients section in the FMS 9.2 User Guide for the Security Server Configuration on FMS IIS Web Server.
  • To modify the value of ServiceUrl, replace localhost with the IIS machine name in ERSService.js file (C:\inetpub\wwwroot\OHCEmergencyMobileApp) of ERS web application.
  • To ensure Database Schema passwords are compatible with FMS 9.2, see chapter Database Schema Password Manager chapter in the FMS 9.2 User Guide.
  • When the installation is completed. Go to the specific FMS component directory, for example, C:\Program Files (x86)\Oracle Hospitality Cruise
    • Add the ServiceURL information to each Component or Add-On .exe configuration file. See below for the example.
      <appSettings>
         <add key="FidelioBkPwd" value=""/>
         <add key="KEKKey" value=""/>
         <add key="ServiceUrl" value="https://Host-Machine-Name/OHCFMSSecurityService/FCTransactionsService.asmx"/>
         <add key="launcher1" value="layout_fms"/>
         <add key="launcher2" value="layout_occ"/>
         <add key="LogExceptionToFile" value="True"/>
         <add key="ClientSettingsProvider.ServiceUri" value=""/>
         <add key="IsActiveDirEnabled" value="N"/>
         <add key="isFileUpdaterEnabled" value="Y"/>
         <add key="isShipSide" value="N"/>
                <add key="Languages" value=""/>
      </appSettings>
      <add key="IsActiveDirEnabled" value="N"/>. Set Y for active directory login authentication
      <add key="isFileUpdaterEnabled" value="Y"/>. Set N for running desktop applications e.g. Data Viewer, Corporate access Management on Windows 10.
      <add key="isShipSide" value="N"/>. Set Y to run ship side interfaces (Sender, Receiver, Watchdog)
  • Launch your application by using the application icon(s) available on desktop.
