7 Performing FMS Upgrade
What You Should Know
Make sure you have an operational understanding as follows:
Personal Computers (PCs) and a working knowledge of Microsoft Windows interface
Understanding of basic network concepts
Experience with Microsoft Windows Server 2016
Experience with Oracle 19c
Microsoft Windows administrative privileges
In addition, you must know
You cannot repair or modify installation features due to changes in the setup process. If a problem occurs, you must uninstall any installed applications and reinstall FMS.
Before You Begin
To upgrade to FMS version 9.2, take note of the following steps:
You must uninstall all the components and add-ons older than FMS 9.2. Follow the steps in chapter Uninstalling Fleet Management Component or Add Ons.
For upgradation process see below sections
You must uninstall all the components and add-ons older than FMS 9.2. Follow the steps in Uninstalling Fleet Management Component or Add Ons.
Follow the steps in Installation of Fleet Management Components and Add-ons
When performing an upgrade to version 9.2, you must perform a database verification and backup task for the databases.
Have a dedicated Client PC ready for an upgrade.
Follow the prompts in the FMS software installation. If you cancel the installation after it starts, using any method other than through the provided prompts; the results can be unpredictable.
You must be logged in as an administrator before running the FMS setup on a Microsoft Windows system.
Ensure that all other programs and applications are closed on the PC. If the system detects an active program or process during the installation routine, a notification to close them may appear.
Pre-Installation Task
You must complete the tasks mentioned in chapter Pre-Installation Task before continuing
