4 Uninstalling Fleet Management Component or Add Ons
This section describes the un-installation steps for Fleet Management Component or Add-On.
Go to the following location:
C:\Control Panel\All Control Panel Items\Programs and Features - Right-click the Fleet Management Component or Add-On you want to remove, and then select Uninstall
To make sure the component or the Add-On is uninstalled successfully, go to
C:\Control Panel\All Control Panel Items\Programs and Features.
